Soundproblem, Motherboard ASUS P5KR
I have a problem with the onboard sound. I only use 2 speakers and connect to the "line out"(lime/green) on the back of the board.
I tell the realtek software (came with the MB) that i use a system with 2 speakers.
The problem is that i only hear sound from the right channel, when connected to the "line out" !
If i use the output made for rear speakers and tell the software that i use at 8-channel system, i hear sound in both channel.
Is there a problem with the board, or am i do anything wrong ?
Best regards
Henrik Larsen
Denmark
  • Islin Feb 13, 2008
    The speakers are powered (Altec Lansing Gateway2000 w/sub (the sub goes to the "sub out" on the MB or the "sub connection on the one speaker).
    I have not configured the jacks ! I have just bought and installed the MB / Software and have not made some special configuration. Regarding the manual (the way i read it !) i have to use the line out (marked green) when using with 2 speakers only, but as written - only sound in the right channel !
    PS: The balance parametres are OK !
  • Anonymous Feb 19, 2008
    I have a speaker &I connect the speaker in sound card but I don't hear any voic I think the proplem is sound card identify
  • 593 Answers
Are they powered speakers? Try using the front panel headphone jack. The colored jacks under the 6.1 are configureable to be used by different speakers, like center channel, etc. Good luck in Vista or XP on a Vista MOBO.
Posted on Feb 13, 2008
What processor supports a am35306 motherboard
HP and Compaq Desktop PCs - Motherboard Specifications, RC410-M (AsteropeA)gtabseps.gif
gtabblt.gif Motherboard specifications table gtabblt.gif Motherboard layout and photos gtabblt.gif Clearing the BIOS settings gtabseps.gif Motherboard specifications table Part / Feature Specification / Support Motherboard description
  • Motherboard manufacturer's name: ECS RC410-M
  • HP/Compaq name: AsteropeA-GL8E
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Presler)
    • Pentium D 800 series Dual Core (Smithfield)
    • Pentium 4 500 (Prescott)
    • Pentium 4 600 (Prescott)
    • Celeron D (Prescott)
    • Celeron D (Cedar Mill)
Front-side bus (FSB)
  • 800/533 MHz
Chipset
  • Northbridge: ATI RC410
  • Southbridge: ATI IXP450
BIOS features
  • AMI BIOS
Form factor
  • Micro ATX size form factor, 9.6 in x 9.6 in
Memory
  • Single-channel memory architecture
  • 2 x 240-pin DIMM sockets support unbuffered non-ECC 400/533 MHZ DDR2 memory modules
  • Maximum HP/Compaq approved memory is 2 GB
Expansion slots
  • Three PCI
  • One PCI Express
Video graphics
  • Integrated
  • Supports PCI Express x16 graphics cards
Onboard audio or audio card
  • Built-in Azalia 8 channel audio
  • Realtek ALC883 8-channel High Definition Audio CODEC
Onboard LAN
  • Realtek RTL8100 10/100 Mbps Fast Ethernet controller
Back panel I/O
  • PS/2 keyboard (purple)
  • PS/2 mouse (green)
  • One SPDIF out port
  • One S-video out port
  • One VGA out port
  • One Parallel port
  • Four USB (2.0)
  • One IEEE 1394a
  • One RJ-45 networking port (LAN)
  • Audio ports:
    • line in (light blue)
    • line out (lime)
    • microphone (pink)
    • side speaker out (gray)
    • rear speaker out (black)
    • center/subwoofer (yellow orange)
Internal connectors
  • Two IDE connectors
  • One floppy drive connector
  • One ATX 24-pin power connector
  • One ATX 4-pin +12v power connector
  • Four Serial ATA connectors
  • One VGA connector
  • One IEEE 1394a connector
  • One CPU fan connector
  • One PC fan connector
  • One CD_IN connector
  • One front panel audio connector
  • One PC panel connector
  • Two USB connectors supporting 2.0 ports
NOTE: Motherboard specifications are subject to change without notice.
hope this helps
Sep 25, 2011 | HP Compaq Motherboard
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Is a sound card worth it?
From my experience, asus has good onboard sound cards. I usually only recommend a sound blaster if you play games or do some audio editing.
Nov 22, 2009 | Computers & Internet
Speakers doesnt play
check the motherboard manual and see if it requires a jumper to enable the audio onboard ( if so get the jumper from your motherboard box and seat it on the correct jumpers in the correct position to enable onboard audio ( assuming its onboard audio that you are using ) If not then ensure your sound card is seated firmly and install the correct drivers ( for either the onboard audio or the dedicated sound card ) and then ensure that the speaker cables are connected to the correct connectors on the sound card ( whether onboard or not ) and make sure windows audio is not muted for any of the auxilary lines ie wave etc and if its realtek ensure that you have 2 speakers selected in the HD Control panel and not head phones.
May 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
There is an inbuilt speaker but the sound is not coming
Hi gogovie_2,
There is only one speaker controller (C-Media 8738-MX), built into the P4B533 motherboard which is where you would connect a home speaker system into the lime green port located at the rear of the motherboard. (See your manual, page 1-7 for the motherboard layout & location of the line out jack for your speaker plug). See pages 1-8, 1-9 & page 1-10 for descriptions of each item shown on page 1-7.
The ASUS P4B533 MB usually comes with a small black speaker that plugs onto the motherboard. You can see the location for this speaker on page 2-33. Number 18 shows the configurations for the 20-pin panel & internal speaker.
This tiny speaker is used for system P.O.S.T. Known as Power On Self Test. During the boot up process a single beep will sound off. This tells you that the motherboard bios has passed P.O.S.T.
If you need the manual for the ASUS P4B533 motherboard you can download it directly from Asus. Click on the link below. Once the link has loaded type the model number, P4B533 in the search window (Upper right hand corner) & click the white arrow.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Click on, " P4B533 related files for download ". The next window will want you to click the dropdown menu & choose your operating system. (Do so). Asus will display all drivers, manual & bios files for the P4B533 motherboard. If you download the manual you'll need Adobe reader to view the manual. You can download Adobe for free at this next link; http://www.adobe.com/products/reader/
If you do not have sound from your home speaker system make sure you have installed SoundMax/C-Media software. This program uses jack auto detecting censer software to help setup your speaker (s). You can also download the latest audio drivers.
If you think you need a new (Internal speaker) you can buy one from here; http://www.pcpartscollection.com/mosp.html
& from here;
http://www.anitec.ca/product/11692/generic_4_pin_speaker_for_motherboards/
Lastly, if the information provided here has not answered your question, please rephrase your question. I'm sure I can provide you with an answer & fix.
Mike
Feb 03, 2009 | ASUS P4B533 Motherboard
Audio connection
the setup for those are ; line in , line out & mic , with the motherboard utility's disk you should have a audio software configuration utility that allows you to change the configuration , like 5.1 output
Oct 07, 2008 | ASUS P4XP-X Motherboard
No Sound
hai
Sep 10, 2008 | Intel Computers & Internet
Motherboard sound issues
Hi antlob,
Normally one would think something is wrong but if you look at page 2-23 in you're manual you'll see you're using the wrong plug-in (Lime green) (Rear). Plug you're spreaker jack into the
(Black sound out jack). See if that makes a differance?
To fine tune you're sound you can open Asus/RealTek sound effect manager listed in control manager. This program has connector sensing software & other goodies.
Enjoy!
Mike
Jul 20, 2008 | ASUS M2N-E SLi Motherboard
No sound from p5k3 motherboard
have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
May 15, 2008 | ASUS Computers & Internet
Computers & Internet Logo
911 people viewed this question
David Payne
David Payne
