Question about HP LaserJet P3005dn Printer
What is MemTest failure replace DIMM0 on an HP Laserjet P3005dn?
Does anyone know what does MemTest failure replace DIMM0 on an HP Laserjet P3005dn means? I been trying to fix oiur computer and no one can figure out what to do or what is going on? Does this mean that we need to add memory? Please help us. Thank you for your time.
  • Anonymous Feb 20, 2009
    MemTest failure replace DIMM0 on an HP Laserjet P3005dn also DIMM1
  • Anonymous May 11, 2009
    What do you mean "formatter"? Is it firmware or hardware?
  • 3 Answers
It says to replace the DIMM, but you really need to replace the formatter. We run into this all the time with this model of printer.
Posted on Mar 04, 2009
WHAT
Posted on Sep 22, 2008
  • 20 Answers
That means -
RAM memory is bad. You can repair it only by replacing RAM module.
If printer has warranty, then it should cover it.
Posted on Feb 13, 2008
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
What does printer code "mem test failure 1/6
Hello carmen_alley,
This means the memory test process failed due to a bad module. DIMM ( Dual In-line Memory Module ) is the memory of your printer. It is really similar to computer RAM (memory).
If the printer is under warranty I would contact the manufacturer for a repair/replacement. If it is not, I would still contact them and get further information on what DIMM you would need to purchase to replace the bad one.
Hope this helps!
Jun 29, 2011 | HP LaserJet P3005dn Printer
Mem Test failure replace dimm0. What does this mean
You have to replace a phisical bank memory from inside of your cpu.
Mar 22, 2011 | HP LaserJet 2420dn Printer
HP Laserjet P3005dn printer makes a loud grinding sound while printing. Prints OK, but users are annoyed by the sound
Replace the fuser and the fuser drive gear. When you order the fuser make sure that they include the gear.
Nov 22, 2010 | HP LaserJet P3005dn Printer
Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Jun 02, 2010 | HP LaserJet P3005n Printer
How do I stop my hp laserjet P3005dn Printer to stop squeaking?
The most common place for these to squeak is the fuser, usually a bushing that holds the lower (pressure) roller has failed and the shaft is grinding against the frame of the fuser. Grinding will usually occur shortly after. You need to remove the fuser and examine where the lower roller's shaft comes out to the gear for bushing wear. Then you can replace the fuser with a rebuilt, or replace the right and left bushings if you want to tear down the fuser. Another squeak can come from a toner having bad bushings allowing the drum to rub the plastic housing of the toner. Yet another could be the bushings holding the final roller shaft for the exit bin, requires removal of the top,
Service manual can be downloaded at feedroller.com - down the left nav bar at the bottom is a link to manuals.
May 20, 2010 | HP LaserJet P3005dn Printer
Hp LJ P3005DN hangs during boot. Sometimes during
It would not surprice me if you have a defective formatter board. This is a very commen problem with this machine. Officialy you have to replace the formatterboard but there is also an other way to fix it. Put the formatterboard in to a preheated oven 190 degrees Celcius (350 fahrenheit) for 8 minutes. 8 out of 10 times it works fine fine and the machine is up and running. If this does not work you still can replace the formatterboard.
Dec 30, 2009 | HP LaserJet P3005dn Printer
Mem test failure
Replace the memory, or take the computer to a qualified technician, to get it replaced.
Dec 08, 2009 | HP LaserJet P3005dn Printer
HP p3005dn does not recognize internet explorer 7.0
We decided to download drivers off the Internet so that at least our printer would show up in the list already on the computer. This HP p3005dn was not in the long list of HPs. Maybe we just bypassed the problem with the I.E. 5.0 and higher issue, but I just needed to get this thing up and running for work.
Sep 21, 2008 | HP LaserJet P3005n Printer
HP LaserJet P3005dn Printer Logo
7,915 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
