Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
How can i unlock my router?
I have a netopia 2247NWG wireless router.i get it from eircom phone line.now i have smart telecom broadband line.but now when i connect it to the smart telecom line, i found wireless connection in my computer that eircom-234543954 something like that.but i cann't access to the internet. i think its lock to the eircom.can you give a right solution how can i unlock this router.because i have the smart telecom router but its not wireless. so i want to make my house wireless by using the netopia 2247NWG which i get it from eircom.
    Sniper:
  • 58 Answers
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Posted on May 10, 2008
    Problem Solver:
  • 15 Answers
Ratrideen,
I'm not entirely sure what you are saying the problem is. Is it that you can't access the Internet from your PC once the netopia router is hooked up? If this is the case check your IP setting on the PC. The following documentation from the Netopia site should help.
Good luck.
J
http://www.netopia.com/support/hardware/2247w.html
Posted on Feb 13, 2008
Good day! I have try to upgrade my Netopia 2247NWG-EIR firmware, but unfortunately my modem was hang. After power reboot my modem now not responding to any answer. But indicator of ethernet ports is light...
hello arthur, you wont need the eircom firmware you just need a firmware update for the netopia 2247nwg-vgx
go here fill out the details and download the firmware and update the router with it
http://www.netopia.com/support/hardware/firmware/updates.html?224xw
Feb 27, 2011 | Netopia 2247NWG-VGx Wireless Router...
Strict NAT type on xbox live...eircom is provider, there router
Follow this link and it'll tell you exactly what to do if the router your using is an eicom netopia http://xbox360help.blogspot.com/2007/09/xbox-live-eircom-router-netopia.html
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
Jan 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
How to change nat type eircom
try to change the MTU settings on the router....
reduce the MTU to 1365
you will also need to open the ports on the router.
click Here for step by step info
Jan 08, 2010 | Netopia 2247NWG-VGx Wireless Router...
Netopia 3347nwg wifi locked!!!
Hello michael,
The lock you see indicates that the network you are trying to connect to requires a password for authentication.
You can access your ipod settings and enter the credentials by following the below steps:
1- First connect to your closed Wi-Fi network
2- Choose Wi-Fi, then tap Other and enter the network name.
3- Choose Security, tap the type of security the network uses, and enter the password.
This should be it.
Have a good day.
Mar 15, 2009 | Netopia 2247NWG-VGx Wireless Router...
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Unlock netopia 2247 router
If your talking about the password for the router user interface that is not working that resetting it again using a pen or a paper clip just press and hold the reset button for 30 seconds then that should bring your router to its default settings with the default username and password.
May 06, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
May 04, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock netopia 2247NWG
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
1,075 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
