Question about Toshiba Satellite A45-S250 Notebook
Purchased new battery, now NOTEBOOK won't work on battery after full charge
This is the 2nd new battery. Probably not the battery.
My toshiba a45-s250 notebook works normally with the original batter with the exception that the battery life is now about 30-50 minutes.
A new compatible battery was purchased. After installation and full charge, the battery ICON shows FULL CHARGE. The notebook will not fully boot when on BATTERY only. It can be booted with the A/C connected but if the A/C is disconnected it abruptly shutdown (no messages) after 3-5 minutes of use.
Swapping back to the original battery returns the functions of the notebook back to normal w/o the benefits of a longer battery life.
Any IDEAs... BTW, I removed and reinstalled the BATTERY from the SYSTEM PROPERTIES->HARDWARE->DEVICE MANAGER without any change.
  • BinaryCalc Feb 13, 2008
    Hmmm... Well I stated that I had already tried two new batteries and fully charged both and the problem persists. I'm right back where I was when I posted this problem.
    No help but thanks for typing.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Your batter may never have been broken in appropriately; Acer, in the fine print, says that to break it in, you must fully charge it, then let it drain completely 3 times! Then you can use it normally. Since most Li ion batteries work the same, this could be a general rule. My notebook tells me when it is fully charged--you don't have to guess.
Posted on Feb 24, 2008
  • Richard Roberts Mar 01, 2008
    You definitely need to go to Toshiba help, as they must know their glitch which causes this. I presume you have returned the other batteries per warranty. Check to see if the specific models have been recalled--that has happened quite a bit. good luck
  • 108 Answers
Better you first charge the battery for 16 to 17 hours and recheck the same. If problem persists, change the battery from where you bought it. that battery is faulty. And yes there is no need to install the battery from device manager. Just open the battery compartment and replace the battery with new one.
Posted on Feb 13, 2008
Driver toshiba satellite a45-s250 wireless network connector
Toshiba Support > Satellite A45-S250 Notebook PC > Atheros 802.11 a/b/g WiFi driver with Cisco WPA support for Windows XP and 2000,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
HOWEVER, it requires the Atheros Client Utility v2.4.2.18, to be installed. If it isn't installed on the laptop, this utility needs to be installed first. Then the Driver above.
If you need guidance in downloading, or installing please post in a Comment.
Regards,
joecoolvette
Oct 08, 2011 | Toshiba Satellite A45-S250 Notebook
My toshiba satelite A45-S250 doesnt start the windows, it keeps rebooting and I am not being able to install it again, my dvd drive isnt working
Unplug the power cord, take out the battery and hold the power button down for 10-15 seconds. This should take your computer out of the reboot loop that it is stuck in. If it doesn't, try using an external CD drive from Wal-Mart or Radio Shack, your computer should register it and you can load the windows CD from there.
Mar 12, 2011 | Toshiba Satellite A45-S250 Notebook
How to reset bios password on the toshiba a45 s250
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD.
Jan 12, 2011 | Toshiba Satellite A45-S250 Notebook
Need driver for ethernet controller for toshiba satelite a45-s250
toshiba download page. (please put the www. before the link)
csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
I think the driver you are looking for is the first on the page -
Good Luck.
Bill
Nov 29, 2010 | Toshiba Satellite A45-S250 Notebook
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S130 boot failure
* If it's a BIOS problem, try this :
1. Shutdown ur system, and remove the BIOS battery.
2. Reinstall it and start again.
3. You can also replace the battery. (if above steps don't works!)
4. Try to get a updated version of BIOS driver. (if above steps don't works!)
* If u r also hearing any kind of beep sounds, it may be bad RAM (memory). Try this :
1. Shutdown ur system, and remove the RAM.
tell me if these steps don't work! :)
Dec 31, 2009 | Toshiba Satellite A45-S250 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 PC - where is the ram located?
The memory is under the keyboard on these models. Remove the plastic piece with the power button, and you will see the screws for the keyboard. Don't forget to rate me (fixya). thanks
Jul 31, 2008 | Toshiba Satellite A45-S250 Notebook
Problem
What is the booting problem, what pops up on the screen ?
Jun 24, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
