Question about HP Compaq nx9600 Notebook
HP Compaq nx9600 PC Notebook horizontal lines when turned upright, but no on side...???
Im having this wierd prblem with it i have it set up it works perfectly on its side but when i turn it right side up it gets horizontal lines on the screen.
If you weren't such a **** maybe it would work.
Posted on Feb 13, 2008
How to remove bottom case of a compaq nx9600
HP Support > HP Compaq nx9600 Notebook PC > Main Support page > Manuals > Service and maintenance information,
Under the bold black subheading - Service and maintenance information, click on -
Compaq Presario X6000 and Compaq Presario nx9600 Notebook PC - Maintenance and Service Guide
Service Manual
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
PDF files do not show until fully downloaded.
This is a Temporary download.
There is a method to saving this manual to your computer.
This way you can burn it off to a CD disk, and have it for safekeeping, and anytime you want it.
Instead of having to go back, and download each time you wish to view it.
If you do not know, and wish to; post back in a Comment.
Moving on........
The Base Enclosure (Bottom Cover) does not come off.
You have to completely disassemble the laptop, all the way down to the Base Enclosure; from the Top.
The Processor, and Heatsink/Fan Assembly is on the Bottom of the motherboard.
To wit;
Bottom view of motherboard,
Wear an ESD wrist strap, and have the alligator clip attached to a good ground source.
Average cost is $3 to $6.
(Electro Static Discharge)
Break any of the motherboard ZIF connectors, and this means MOTHERBOARD REPLACEMENT.
(i.e, Keyboard Cable motherboard connector, Touchpad Cable motherboard connector, etc)
Need step by step guidance in disassembling, post back in a Comment.
Mar 26, 2013 | HP Compaq nx9600 Notebook
Compaq HP nx9600 notebook will not power on, even with known good battery or by direct power. It was working fine before turning off. No lights, no signs of booting or power.
First, remove battery and insert power cable then try switching it on. if it powers, then insert battery back when its powered. if it doesn't power, check your power adapter first and make sure it didn't get blown. check whether voltage is reaching. Regards
Feb 10, 2010 | HP Compaq nx9600 Notebook
Need a workable seconds LCD 17'' screen for Compaq
the screen is most likely ok sounds like your power inverter for the screen on the laptop is going out if it is that is a cheep fix compare to replacing the screen a computer rerpair shop that works on laptop should be able to fix that for you
Mar 23, 2009 | HP Compaq NX9600 17.0-inch WSXGA+...
Compaq nx9600 laptopshuts down unexpectedly, have run memory tests and memory seems to check out. All fans work although it does get rather warm at the exhaust ports. Hard drive tests ok.
Most laptops (recent older 1's) *must have* ventilation under them. Do *not* ever use on a soft surface - preferably prop it up a bit when in use - and when running and not in use!
Mar 20, 2009 | HP Compaq NX9600 17.0-inch WSXGA+...
Compaq nx9600
Shorted DC connector.
Mar 06, 2009 | HP Compaq nx9600 Notebook
Unable To connect To The Internet
what kind of internet conection is that one?
Jan 08, 2008 | HP Compaq nx9600 Notebook
HP Compaq nx9600 Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
