Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer wont go through the spin cycle
My kenmore washer will do everything except go through the spin cycle. It makes a loud noise like its supposed to be doing something,but nothing happens. My brother looked at it & said there's no belt in it. Iss this an easy & inexspensive fix or should I buy a new washer?
  • 5 more comments
  • jiana Feb 13, 2008
    it fills with water,it does drain & agitate.i can turn the drum,but theres alot of play in it.it doesnt hand spin start with the lid switch pressed in......
  • Chloesmom06 Feb 24, 2008
    My Kenmore washer will not go into the spin cycle. it does do
    every thing else. It does agitate fine. But like this
    morning, I went in there, it had not spun and it flooded the
    floor. Should I junk it and get a new one or is this something
    easily fixable? I have checked all the hoses when I saw the water
    all over the floor, and none of the hoses are loose.
  • kermatose Feb 26, 2008
    It's not exactly the same model but I'm pretty sure it's the same type made by another manufactuer. Every thing works but the spin cycle, I had it apart to because it wasn't draining and pulled something out of the water pump that had it clogged up. It is a direct drive system and will go through a full cycle on the dial. The clothes are sopping wet and when I set the washer on spin directly I cand hear a repeated clicking sound. I can see the shaft output from the motor spinning at this point. Is there anything that I can check before i purchase parts or get a repairman?
  • Anonymous Apr 25, 2008
    my kenmore washer will not go through spin cycle.
    it only makes a really loud grinding rubbing noise.
  • david evans Dec 08, 2008
    My problem is the same as Jiana`s Please help
  • Anonymous May 13, 2009
    my washer does not spin leaves clothing wet. I checked for a belt there is none
  • kermatose May 11, 2010
    yes it agitates fine and all the water drains out, i can also spin the tub by hand. the only thing missing from the equation is the spin dry cylcle. when I had it apart i really didn't understand how a washer worked so i took more apart than i really needed to. The water pump is on the back side of the motor and that's as far as i needed to go. when i took the motor off of the bottom assembly of the tub maybe I screwed up the tub (clutch)?), i didn't pull it apart but it seemed as if it dropped down a half an inch farther than it was before. I had to push the motor in hard in order to put the three bolts holding it on back together.
I poked at the sensor (sensor that is is the safety lid switch) which is on the right hand side of the top of the machine. The water pumped out and it went into spin cycle. When I released the switch or lever to activate the sensor, the cycle stopped. I then proceeded to unscrew the sensor switch. I carefully I pushed the sensor pad up (It was stuck). Screwed the switch back in place and ...Wha la! She is running like a top. This sight is very helpful. I love not having to pay anyone to fix my problems! Kudos!!!!!!!!!!!
Thank you!
Posted on Mar 25, 2008
I took the lower front cover off of my washer.  There is a pump that pumps out the water.  The hose from the drum (the thing that holds the clothes and the water) has a square thing that I guess works like a pea trap.
I removed all the items on the pea trap.  Removed the hose.  Removed the drain hose and looked at the motor.  there was something stuck, a piece of bra pad, in the motor splines.  I put everything back and the washer workde just fine.
Hope this helps someone.
Fred
Posted on Mar 30, 2008
  • 770 Answers
He is right there is no belt in that unit only the older models had a belt they are direct drive now It sounds like you have a basket drive problem but before I tell you thast for sure i need some answers to these questions Does it Agitate ok?? does it pump out all the water. With the lid switch press in and the unit in spin cyle can you hand spin start the unit?? After you answer that it will give me a better idea of whats going on.
Posted on Feb 13, 2008
  • Gary Davd
    Gary Davd Mar 13, 2008
    Good Luck Thanks For the Rating
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer makes very loud noise during the spin cycle.
Sounds like you have bad bearings. If you use powder soap thats the problem. Powder soap doesnt dissolve all the way and gets into the bearings and eats them away. you will most likely have to have a service technician come out to replace them(Its not just bearings they sell you more than you need and you have to take everything apart... big job). After that use liquid soap.
Nov 16, 2008 | Kenmore Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
1,626 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
