Question about Acer Aspire™ T180 PC Desktop
Computer shutdown I purchased my computer in October of 2007. I am continually experiencing shutdowns/computer lockup when I am using the computer. What can I do to correct this problem?
  • Anonymous May 09, 2008
    I have an Acer Aspire 5630 laptop and it locks up without warning. The lock up only lasts for about 8-10 seconds and then the problem disappears. I suspect it may be interference atacking the wireless card, as I run from a router in another room. When I am hardwired to the modem this does not happen. I have increased the ram by double to 2 gig. I am also on my second mother board and still get lock ups.
    Sergeant:
  • 406 Answers
If you are using Xp / Or vista Operating system make sure that you have antivirus installed and firewall enabled. Scan your computer for viruses and spyware etc. Make all the parts of computer is functioning. If everything is fit and fine try changing Memory of the system...
I hope this will solve your problem. If same problem continues do not hesitate in replying may I will provide a another alternate.
Best Regards
Rafique
Posted on Feb 13, 2008
I purchased HP Compaq Presario CQ42 in october 10. Now i am facing problem of overheating and system shuts off automatically. Please suggest some solution of my problem.
Observe if the processor cooling fan is spinning that cools your processor. Or your unit need cleaning where the vents of your laptop is clogged with dust and the cooling system will be affected that made your system shutdown automatically
May 27, 2011 | Computers & Internet
PC Getting auto shutdown
The most common reason of a PC getting auto shutdown is that the processor may be getting over heated.
Every processor has a TjMax temperature. when the processor reaches that temperature, it starts throttling(slow down) and if it continues to become more hotter then it automatically sends a shutdown signal to the Computer
Solution:-
  • Clean the Heat-sink.
  • Check the fan speed.
  • clean the cabinet.
  • use thermal paste over thee processor.
  • Make sure there is proper ventilation in your cabinet.
Hope this may help you......cheers:)..plz vote
Sep 24, 2010 | ASUS P5PE-VM Motherboard
LP70 is experiencing auto shutdown if connected to a laptop
shutdown connected or not is shutdown. this is likely a grounding problem between the main board and the power supply.
Jun 03, 2010 | InFocus LP70+ Multimedia Projector
Hello i have problem with cmd i want to shutdown a computer that in network so pleas help me out i have typed shutdown -i and in cmd and i type his ip ... and i clicked ok and its saying erre that invalif...
You have to enter following command in command prompt.
c:\>shutdown -m \\it -s
Shutdown - This is the command u use to shutdown/restart/etc
-m - It means remote computer.
\\it - This is the computer name which you want to shutdown
-s - You have to enter this command (-s = Shutdown, -r = Restart, -l = Logoff, -a = Abort shutdown)
Hope this is working for you. If not, comment back with the problems. Thank You...!!
May 04, 2010 | Dell Inspiron 1501 Notebook
I have an Optiplex 210L and want to add on a video card. I came across an EVGA GeForce 9400gt 1GB PCI card and decided "why not!" after disabling the onboard video and setting the bios to auto (or look for...
Remove the GeForce card.
Enable the onboard video as "primary".
Start Windows.
Within Device Manager, remove the driver for the GeForce adapter.
Download the latest software software for the GeForce video-card,
and install it.
Shutdown.
Insert the GeForce card, and leave the onboard video as "Primary".
Start Windows.
It should treat the GeForce card as an "additional" video-adapter,
as if you had two monitors, side-by-side.
If it works in this configuration, shutdown.
Set the GeForce card to "primary" and restart.
Set the onboard video to "disabled".
Restart.
Dec 27, 2009 | Dell OptiPlex 210L PC Desktop
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Machine freeze up randomly. Must do a hard shutdown. Seems like a motherboard failure Does anyone know how I can get support for my M465-E laptop? MPC is not responding to any of my emails and their...
Hi, "marspkr": First you stated that you had to "do a hard shutdown" because of this unit locking up...then at the end of your message you stated that it "keeps rebooting itself over and over". Should usually be one or the other. As I stated above, with the laptop I was working on, it turned out to be a complete HD breakdown. Now the owner has to decide whether to purchase another Hitachi "Deathstar" or just give up and buy a new model. Usually 2 or 3 things would cause a complete lockup requiring a 'hard shutdown'. 1. HD failing, 2. Bad or unsupported RAM, or 3. Overheating onboard video. All of which are pretty crappy considering that neither GW or MPC are in the biz of customer support anymore.
If you are experiencing a constant rebooting scenario, I would reccommend going into safe mode and running any number of the freeware tools out there to help with malware/virus activity. For example: "MBAM", "ComboFix", "A-squared", "HiJack This", etc. Most of these tools have instructions at their site of origin and have always come in very handy for my use. Much luck to you.
Regards, Holibug
Apr 06, 2009 | Gateway M465-E Notebook
Shutdown problems
Windows does not shut down. Windows 95/98/ME may not Shut Down successfully or may lockup / freeze because ... may be difficult to trouble shoot or determine where the problem exists.
E-mail CHID: 5608 WHILE I SHUTDOWN THE COMPUTER IT WILL TAKE LONG TIME TO SHUTDOWM PROPERLY.
Read and follow instructions.Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
Shut down icon
That is a strange problem.
I will help you to create a shortcut on your desktop for that icon, whenever you need to shutdown your computer, just click that shortcut on the icon.
Right click on the Desktop.
Left click on New > Shortcut.
In the Type the location of the item: textbox enter
%windir%\System32\shutdown.exe -s
The -s parameter is used to shut down the computer.
The following two parameters can be used with -s:
-f Forces running applications to close without warning.
-t xx Set timeout for shutdown to xx seconds.
The following command would shut down instantly.
%windir%\System32\shutdown.exe -s -f -t 00
Click the Next > button.
In the Type a name for this shortcut: textbox enter
Shutdown My Computer (or some other name of your choice)
Click the Finish button.
Whenever you want to shutdown your computer, click the shortcut on your desktop that says ShutDown My Computer, and your comptuer will shut down the usual way, the way it used to shutdown.
Actaviosan
Nov 17, 2007 | Compaq Presario 5000 PC Desktop
Freezes up
This error can be caused by one or more of the below possibilities:
HDD
Power suply
Ram
Cooler dont work propertly
Or you are infected with virus
But most of those problem happent when HDD is damanged!
Oct 30, 2007 | IBM ThinkPad T20 2647 Notebook
Acer Aspire™ T180 PC Desktop Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
