Clarity bobcat monitor, no picture black screen
Unit has black screen will not show picture. A co worker was able to get the unit to work for a couple of hours prior to it returning to a black screen.
Thanks,
Dan
  • OCboss Mar 13, 2008
    I seem to have the same problem. Hava you found out what it was?
  • 286 Answers
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
Two possible causes are bad capacitors or a bad light inside the LCD panel.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
Also, you may have a bad light inside the panel. This is tough to test without a spare light to use for troubleshooting.
You can take the panel apart and inspect the lamps but it is very tedious. It's tough enough to get them apart and back together again never mind keeping the layers clean. You have to try not to get any dust between the layers or you will see it in the picture.
There are usually two light fixtures each of which holds two lamps. One fixture is at the top and one at the bottom. Remove them one at a time and inspect the lamps to see if any are broken or very dark on the ends. If one looks out of place, it could be bad.
You'll have to find replacement lights on the net. It's not easy to replace them, but if you've gone this far, good luck. You should be able to get generic instructions off of the site that sells the lamps.
Posted on Feb 14, 2008
HP f1503 flat screen monitor remains bland when i turn it on, though the monitor light shows it is on. I can shine a light on the screen, and see that it is working, but not bright enough to see.
Posted on Jul 20, 2008
ET183105 PC Desktop black screen
Either your monitor or video card is bad. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not work, then the Video Card inside the computer is bad.
May 19, 2012 | eMachines ET183105 PC Desktop
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
Black screen after changing resolution
Try setting your resolution back to the way it was and see what happens.
Maybe your monitor or video card is bad.
To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor, then the video card inside the computer is bad.
May 18, 2012 | Dell Computers & Internet
Black bar on right side of screen
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black bar on the right side of the screen that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black bar on the right side of the screen it means your video card inside the computer has the issue.
May 18, 2012 | Alienware PC Systems Computers & Internet
My sony vaio d screen sometimes go black
Sounds like the Monitor or Video Card might be going bad. Try plugging another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the computer. If the Borrowed monitor works without going black, then your original monitor is bad. If the Borrowed monitor goes black like your original monitor, then your video card is going bad.
May 15, 2012 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
Black screen just after boot window from USB
Sounds like either the monitor or video card inside the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a friend, neighbor, relative or co-worker and plug it into the computer. If the borrowed monitor displays ok, then your original monitor is bad. If the borrowed monitor does the same thing and not show a display then your video card inside the computer is bad.
May 09, 2012 | Computers & Internet
No data in panel
Either your monitor is bad or the video card in the computer is bad. To isolate the problem try another monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it in the computer. If the monitor works and shows the display then your original monitor is bad and needs to be replaced. If the borrowed monitor does the same thing and does not show anything but a blank screen then the video card inside the computer is bad.
May 08, 2012 | Computers & Internet
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
Computers & Internet Logo
1,063 people viewed this question
David Payne
David Payne
