Posted on Jan 22, 2010
No surround on LG HT904 when using iPod
I just set up my LG HT904 and can only get sound out of two speakers when using the iPod dock. Full surround with DVD however. any suggestions?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 17, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
453
Points
0
Hi I can't get the rear speakers to work at all?
Anonymous
Level 1:
New Friend:
  • Posted on Feb 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
453
Points
TRY TO CHOOSE THE SOUND TYPE TO BE MATRIX
tip
How to make a connection to an iPod and Sony SS2300
<p>The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system. <br /> <p><br /> <p>1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod. <br /> <p><br /> <p>2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod. <br /> <p><br /> <p>3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected. <br /> <p><br /> <p>4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system. <br />
on Aug 09, 2011 • Apple iPod touch
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Ipod tower brookstone problem
The problem is with the speaker connector to your ipod. I have the same unit. Got to ebay and buy Pyle Home PIDOCK1 or similar docking station. This will solve your problem. You can plug this in and have full functionality back of your speaker. Don't bother trying to fix it these have a real problem with the connector and board buy yourself a docking station with remote for about $15 on ebay and it will fix you up. Plug into the input Jack and you are back in business. You can buy a Pyle Home PIDOCK1 Universal iPod/iPhone Docking Station cheap on ebay and it has a remote. It will fit nicely on your speaker and do everything you need it to do.
IPod Touch 4th Gen will dock. Will Charge. Can use remote control to play, and shuffle songs from iPod, but sounds will not come through speakers on Philips SBD8100 Speaker Dock for iPod and iPhone
Hi Sniper326,
try cleaning the input socket of the Philips Speakers with a cotton bud, try cleaning the socket of the Ipod touch cable as well.
Have you tried using the IPod touch with different speakers? and does it work? if so the problem lies with your Philips speakers.
I hope this helps, good luck!
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
2helpful
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Wont play out of docking speakers
Hi
My iPod does the same it does not play out certain speakers.
Take back the speakers.
Take back the ipod.
Go to:http://www.apple.com/support/
Tom
My 2yr old was playing with my ipod in my griffin speakers
Unfortunately, it sounds like she broke the jack inside of it. It has lost connection to the main circuit board, and is of course now useless. If you know what you are doing and it is NOT under warranty, you could try opening it and resoldering it, not that it will definitely work. Otherwise, if it is under warranty, back it up (if you can), and take it back to the store.
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
