Question about Gateway 556GE Intel Pentium 4 630 3GHz(HT) / 512MBDDR / 200GB SATA HDD / DVDRW Dual-Layer / Flash Me... (RB556GE) PC Desktop
No video It appears that everything works except monitor. it stays black I have tried 3 monitors all are the same I believe this computer may have took a surge from the power going on and off what to do what to do...tks....Harry
  • Christopher Peckham
    Christopher Peckham May 11, 2010
    Do you have a video card or is it onboard?
    Have you tryed resetting the CMOS?
    Do you get any warnings "audio/leds"?
    Is there a bios post screen or anything at all at any point?
    Try a different Video/Graphics Card. Or try taking out the one you have "if you have one" and then putting it firmly back into the slot.
    When you answer above questions I may be able to provide another cause, good luck,
    Reeves
    President:
  • 2,351 Answers
Tomcat100,
Your PC has an Intel Graphics Media Accelerator, Integrated Intel Graphics Media Accelerator 90 Up to 64 MB shared video RAM. In other words it's not removable but built into the board.
Ram that is taken from your system memory. What is real good is that you have, 1 PCI Express x16 Slots (open). Which means you can disable the onboard video & use the PCIE video card. If you feel that the system is running as you mentioned, adding a PCIE woulb be a logical next step. I'll suggest a PCIE listed at the link below.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005814
This card comes with a Lifetime warranty & a great price.
Luck!
please vote...
Posted on Feb 13, 2008
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
My Soyo monitor (DYLM1998) stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again. If I turn the monitor off/on several times, it finally...
your power supply has a short in it this is comon ive seen this before try to replace cord if attatched take it to someone for repairs if not attatched its the cord most of the time loose wire..
Apr 10, 2011 | Soyo DYLM1998 Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
Mine similar except the blue light stays on ,monitor goes black
Have you tested the monitor? The monitor could be faulty. Try hooking up the computer to another monitor or another computer up to that monitor if possible. If the monitor is testing good then make sure all USB devices are disconnected and try to boot again. Then open the case and blow out any dust. Check the motherboard screws are tight. If the screws holding the motherboard to the case are loose it can cause a grounding issue. Then swap out the power supply with a working one and see if that fixes it. Disconnect hardware one at a time and re-boot. One of the devices...cd-rom,harddrive,ect could be faulty. Make sure the video card is fully seated and test the card in another working computer or test a working card in that computer. If it has on-board video then install a video card if available and see if it works. If none of these things work then the board is bad and needs replacement.
Sep 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
No image on the monitor
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 17, 2009 | Acer AL1916W 19" LCD Monitor
Cpu does not connected to monitor
I am guessing that you see lights on your computer, but no display on your monitor.
Have you tried another monitor? If you have and still no display, try unplugging everything from outside the computer except the monitor and then try again.
If no display, unplug power from computer and open the computer. Remove all expansion cards other than the video card. Disconnect all the cables from all of the drives, then connect power and try again.
Let me know if you need more help.
Honest1abe
Feb 25, 2009 | ASUS P5V800-MX Motherboard
No pic on screen
Double check all of your connections. It appears the video cable is not plugged in completely. Try another monitor if possible to see if the computer is actually outputting video.
Jan 03, 2009 | Dell Computers & Internet
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Black Monitor
Try taking out your battery and leaving it out for 5 minutes.  During boot press F2 to access BIOS to check your default video out source is LCD.  Also try Fn+F5 to change the modes of video after you think windows is all the way booted up.  Does it POST?  When booting does the drives make noise then hear a beep.  If it beeps it passed Power On Self Test.
James Mac
Sep 09, 2008 | Toshiba Satellite A105 Notebook
Gateway 556GE Intel Pentium 4 630 3GHz(HT) / 512MBDDR / 200GB SATA HDD / DVDRW Dual-Layer / Flash Me... (RB556GE) PC Desktop Logo
339 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
