Math a tank was 1/2 full of water. after 420 gallons had been taken out, it was 1/8 full. find the capacity of the tank?
  • 37 Answers
If it was 1/2 full, and is now 1/8 full, that means 3/8ths was removed. So 3/8ths of a tank = 420 gallons.
Divide by 3, and you get 1/8th = 140 gallons.
Multiply by 8, and you get 1120 gallons total capacity of the tank.
-John
Posted on Feb 13, 2008
Wow! I just happened to be browsing for a different purpose, and I read this question, then looked at the answer.
The way you wrote the answer out somehow opened a memory
"block" of mine and I was able to fully understand it! When I couldn't have done it before! I'm talking a matter of years. I'm now 51 years old and I couldn't have done this TWENTY years ago. Or, maybe I had it all along and somehow you just smacked me on the right side of the head to knock out my cobwebs. (Right, as in correct, not as in opposite of left, lol).
This may not sound like much to some of you, but for me, struggling with memory problems and physicall illness, etc. this was a pretty major breakthrough for me. I just wanted to thank you!
Posted on Mar 20, 2008
What is the formula to figure how much water is in a ractangular fish tank
the volume formula is what is used to determine the amount of water in a tank
that is length X width X height (depth) that determines the cubic capacity or the tank
now 1 cubicft = 7.48 gallons
so as an example-- a fish tank 3ft X2 ft X 2ft = 12 cubic ft =12 X 7.48 = 89.76 gallons
Dec 15, 2016 | Vacuums
Have a 2001 bayloner throphey how much fuel it holds
Are you sure you don't have a 2001 Bayliner Trophy? ;>)
7 gallons, but they come in sizes 17 feet to 31 feet and 125HP to 225HP.
2001 Bayliner Trophy Asking Price: $13,999 OR BEST OFFER Condition: Good. Description Location: Ridgewood, New York Seller's Notes: AWESOME BOAT!! Body Style: Power Boat Length: 21 Hull: FIBERGLASS Class: FISH/SKI BOAT Engine: 2010 Hyundai 150 # Engines: one Fuel Capacity: seven gallons Horsepower: 150 VIN: Request the VIN Seller's Comments Great boat, Lots of storage, 270 hours on motor, Well maintained, Reliable, Great for the lake, Depth/Fish/GPS System, Well equipped, Live well, Pump, Anchor, Seats four, Lots of cabin room, Equipped with toilet.
Easiest way is to run it dry with a 1 gallon portable can on board. Stay close to the marina until main tank runs out, top up with the gallon can, and then go to the marina and fill it up. Whatever it takes minus 1 gallon is the capacity. Then refill that gallon can and log how many miles you do on a full tank. I carry 2 x 6 gallon tanks, I know one tank will take my 95 kilometres (I am in Canada)
Red portable fuel marine tanks hold 6 gallons. The size is marked on it. If you have a fixed tank, they are usually 20 gallons, but to be sure use my method and a fill.
Bayliner Trophy 2002
May 14, 2016 | Cars & Trucks
The coolant in mill should be mixed ratio 32 parts water and 1 part coolant.it has 99 gal and is 40% full.existing mixture has 23 pts water and 1 pt coolant.i have to get it back to 32 to 1
Add 38 gallons of water to the current mixture assuming you have a 250 gallon tank. This will bring your current ration back to 32 to 1
99 gallons / 23 = 4.3
4.3(32-23)=38.7
99 gallons + 38 gallons = 137 gallons.
250 gallons - 137 gallons = 113 gallons Left to fill
113/32 = 3.5
Add 3.5 gallons of coolant to the remaining 113 gallons of water needed to fill your tank completely.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 17, 2016 | Cars & Trucks
When run on high all night, the humidifier only goes through the smallest bit of water, when it used to use up the whole tank if turned on high. Any ideas on how to get it back to full capacity?
try pouring a little vinergar in the water and let it clean and only use distilled water in the humidifier otherwise the impurities will stop it up
Dec 07, 2015 | Crane Penguin 1 Gallon Humidifier
CAR switches itself off when fuel is on querter tank
check the calibration of the sender unit as may actually be on empty. Find out the exact capacity of the tank and add a known amount of fuel and see where the gauge reads. For example if the tank is 60 ltrs or 20 gallons add 5 gallons and see where the gauge reads. 5 gallons in 20 gallons should read 1/4 or in your case after the engine stops should read 1/4 full. If it reads 1/2 then the sender is out.
Sep 11, 2013 | Cars & Trucks
2006 Chevy Uplander LS coolant capacity?
Cooling SystemTotal Cooling System Capacity (qts) : 12.15
Source: chevrolet-uplander-4dr-ext-wb-fwd-ls
Aug 24, 2012 | Cars & Trucks
It has two gas tanks and I need to know the volume, in gallons, of each?
The rear tank is rated 22 gallons, the side tank is rated 19.5 gallons (actual usable capacities are about 1/2 gallon less than posted capacity).
Please rate my help, thanks
Sep 27, 2010 | 1991 Ford Econoline
A drain tube in the water dispensing module constantly has some water flow. What is the purpose of this drain and how can I eliminate the water loss.
A reverse osmosis system drinking water system will waste a certain amount of water for every gallon it produces.
1. The higher the TDS (total dissolved solids) the higher the ratio of waste water to product water.
IE: An RO on TDS of 1000ppm may require 7 or more gallons of water to waste to 1 gallon of product water. TDS of 100ppm will have about 3 gallons of waste to each gallon produced.
2. It also depends on the Membrane capacity. Membranes for residential RO systems come sized from 7-75 gallons per day. If you are a heavy water user and have a low producing membrane the RO may not shut off until it gets to rest at night and fill the tank.
3. There can also be a problem with the automatic shutoff on the RO. When the tank fills up and the pressure equalizes across the system the ASO (which is just a simple diaphram system) shuts the water off to the system.
4. If there is not enough pressure in the RO tank the tank may fill up but there may not be enough back pressure to shut the ASO off. So the waste and product water go down the drain and it runs constantly.
RJ
May 21, 2010 | Culligan Under Sink Water Filter
Ford windstar3.8 engine MPG
15 city 18 combined 22 highway
Aug 13, 2009 | 1995 Ford Windstar
Find the capacity of the tank
420 +X/8 = X/2 420 = X/2 - X/8= 3X/8 X= 8/3 * 420 X = 1120 Tank capacity
Jul 09, 2008 | 2002 Isuzu Trooper
471 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
