Phillips model # 9P5034C101 Projection TV picture tube
Was wondering how hard is it to replace a a picture tube for a Phillipsmodel # 9P5034C101 Projection TV? It's an older model I think, is thispart still available somewhere?
  • Anonymous Mar 30, 2009
    prices of piture tubes
  • Mike Owens
    Mike Owens May 11, 2010
    Well lets start here with the part numbers: Blue 932212133682 Green 932212132682 Red 932212131682 Each are about $285.00 then mabey $300.0 to get them installed and realighned, So guess we should ask the question what makes you think you need new CRT's?
I have a Philips 50 inch rear projection when I power up I have no sound or picture is it done or fixable?
Posted on Oct 01, 2008
Phillips tv has a dark picture
Is it a LCD or a CRT Phillips TV.
If LCD - could be the lamp just getting old (lot of hours on lamp). Could find the model # of the TV and do a Google search of the TV Model # to find a replacement lamp. If its an older CRT Projection TV the tubes may be getting old and unable to illuminate/glow as they used too! Much like a old set of headlamps on a car.
Nov 10, 2014 | Televison & Video
Phillips Magnovox
Its a power supply issue the only solution is to get it repaired.Possible power outage.Repair charges would be around $400.
Goodluck,
Please don't forget to rate the solution
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Phillips 50p8341a
Replace the coolant in the CRts thats a common problem with Phillips and magnavox rear projections. Heres a link to the coolant replacement kit for your model. The kit contains the replacement coolant and step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 12, 2009 | Philips 50P8341 50" Rear Projection...
TV repair
you need to replace the coolant in the CRTs ( picture Tubes) you can get the repair kit at the following link which contains all the coolanr and the instruction CD with the step by step instructions with pictures so you can easially do it yourself. Heres the link.
Aug 17, 2008 | Philips 9P5544C 55" Rear Projection...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
How to replace the crt on a phillips rear projection tv
No trick... It's a difficult task for most techs. On a scale between 1 - 10 and 10 being the most difficult you have a 10.5 there and the fun is just beginning..
Nov 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Phillips Proj TV 9P5034c101
call tech..converge eprom has to be changed from old to new board.
Nov 16, 2007 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
549 people viewed this question
Top Televison & Video Experts
