Question about i-mate Pocket PC
Video playback my pocket pc i-mate pocket pc model no.PH 10B can't play video files. the video file recorded by ppc can play what to do ?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
Cant playback video files
after i got full hard desk on my sony HD (HDR-XR520) any vide i record i cant copy it and it doesn't appear on my computer and then the files on the camera when i play them they don't ply and i found a message said: No applicable files available, so please how can solve this problem? or it's an industrial bad side with this camera??
Apr 28, 2010 | Sony Handycam HDR-XR520 High Definition...
Tip
TV via DLNA-Playback AVCHD MTS/M2TS files on the big Screen TV via DLNA
Watch/Play Videos via DLNA-Connect variety PC/Camera/Device to TV via DLNA <br />Enjoy AVCHD M2TS recordings on DLNA certified TV via DLNA <br /><br />How would you <b><a href="http://panasonic-avchd-converter.com/2011/07/tv-via-dlna-playback-avchd-mtsm2ts-files-on-the-big-screen-tv-via-dlna/">Enjoy/Watch/Play Videos via DLNA</a></b> on a DLNA-certified TV? It would be perfect if your camcorder is also certified with DLNA. The most important element is the home network. However, there is a limited amount of AVCHD camcorders for DLNA. So you would need a PC connected to HDTV via home network, and watch them in the living room with your family and friends. <br /><br />First of all, let's take a look at the supported file formats by DLNA. <br />Media Format: <br />Image: JPEG PNG, GIF, TIFF <br />Audio: LPCM AAC, AC-3, ATRAC 3plus, MP3, WMA9 <br />Video: MPEG2 MPEG-1, MPEG-4*, AVC, WMV9 <br /><br />AVCHD files in .mts and .m2ts encoded in MPEG-4/AVC are supported for streaming through DLNA. However, when you play different files, there would be buffering for loading each file. Aunsoft Final Mate is the recommended AVCHD joiner for <b><a href="http://www.aunsoft.com/final-mate/">lossless DLNA streaming formats</a></b>. You can join the clips into one single file, <b>Connect and enjoy HD recordings on HDTV</b>. <br /><br /><b>Part 1: Lossless join AVCHD for DLNA streaming on your networked PC</b> <br /><br />Step 1. Import AVCHD MTS/M2TS files to Aunsoft Final Mate. <br />Run Aunsoft Final Mate, and you can capture videos from the camcorder connected to PC through the pop-up wizard. Alternatively, for the videos on hard drive, just the "Add file path" and browse the folder with .mts or .m2ts files from hard drive. <br /><br />Step 2. <b>Join AVCHD for DLNA</b>. <br />Click the "Create New Movie" button on Movies tab for lossless output, drag and drop clips from Camcorder tab or Resource tab to the Movie ID. When files are dropped into one movie ID, the clips will be joined as a single file. You can create another movie for different events, and <b><a href="http://www.aunsoft.com/final-mate/">enjoy AVCHD files via DLNA</a></b>. <br /> <br />Step 3. Export MTS/M2TS file for DLNA streaming. <br />Click the "Export" button, and then the OK button. The MTS/M2TS joiner for HDTV will start combining short clips without delay/pause, retaining the native format as DLNA supported file. <br /><br /><b>Part 2: Enjoy AVCHD recordings on DLNA certified TV</b> <br /><br />Step 1. Add lossless videos to your designating folder on PC for sharing to DLNA certified TV. <br />In this process, certain PC share manager software may be needed according to different DLNA certified TV sets. Let me take SAMSUNG PC Share Manager as an example. After you install manager software, a simple way to share videos on your home network is to create and name specific folders on PC for DLNA certified TV to access. Create a new folder on your networked pc, and then name it accordingly, for example "Videos". Copy or load in converted HD videos to the folder you want to access. <br /><br />PC Share Manager will only access those folders you designate as being shared. Here's how to do that. Select a folder you would like to share, or create a new folder for sharing. <br /> <br />Step 2: Enjoy AVCHD recordings in your DLNA certified TV <br />Accessing the joined AVCHD files is as easy as pushing the WiseLink button on your Samsung HDTV. Make sure that your media server or networked PC is turned on and the PC Share Manager application is running so that WiseLink Pro can find your shared files and folders. <br /><br />You can access WiseLink Pro directly from your remote, or from the main menu. (The red Device button, located directly below the Info button on your remote control, lets you choose between one or more networked PCs and the WiseLink USB connector on the side of your Samsung HDTV.) Once you have started WiseLink Pro, you will see the main menu shown below. <br /> <br />Then you can choose the AVCHD files for <b><a href="http://www.aunsoft.com/final-mate/">playback on the big screen TV via DLNA</a></b>, and share videos at home. <br /><br /><b>Tips:</b> <br />1. Aunsoft Final Mate also supports 64-bits and 32-bits system. <br /><br />2. In case that your HDTV does not support AVCHD format yet, you would need to convert AVCHD to TV supported format like .mpg. Just create movie for conversion in Step 2 of Part I on Aunsoft Final Mate.
on Jul 01, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to Play TS Video Files on Computer? There are many worldwide TV channels...
There are many worldwide TV channels like ABC, NBC, CBS, TNT, ESPN so that we can enjoy movies as we like. Is it possible to record TV shows? Of course, yes. You may find DVRs, TiVo Premiere to record your favorite TV series. You can also use TV tuner to record videos. PCTV nanoStick is one of the USB DVB-T TV tuners, which you may use to record ABC/TNT/ESPN videos.
If you record TNT video files on PC with PCTV nanoStick, you may find the output videos in .ts format. The TiVo Premiere can also produce .ts videos. To play the recorded videos on computer via home network, you may find the .ts file format is not a good choice. The general However, you can convert .ts to .mp4 for easy playback on computer players like Windows Media Player, VLC media player, QuickTime Player.
Here are the simple steps to convert recorded TV shows to computer for easy playback.
Step 1. Load recorded ABC/TNT/ESPN videos to Aunsoft Video Converter.
Run Aunsoft Video Converter as the TS Video Converter on your PC, and click the "Add" button to load the recorded videos for conversion.
Step 2. Choose H.264 MP4 output.
Click the "Format" option and choose Common Video > H.264 Video(*.mp4) to convert recorded videos from .ts to .mp4 for playing on any computer. The file format .mp4 is compatible to almost all computers, and the video compression with H.264 will keep video in high quality with small file size.
Step 3. Convert TS videos to MP4 for PC playback.
Click the convert button under the preview window and the TS video converter starts converting recorded ABC/TNT/ESPN videos to MP4.
After the videos are transcoded to MP4, you can put the videos to NAS to archive the videos, and watch the videos on computer via home network. No matter your videos are from TiVo Premiere, PCTV nanoStick or DVR for TNT videos, ABC videos, you can then freely enjoy movies at home. Aunsoft Video Converter is the partner for your recorded videos for playing .ts files on computer. If you are using iMac/MacBook Pro, you can use the Mac TS video converter to facilitate HD video playback.
on Jul 15, 2010 | Cell Phones
How to put games on imate jamin
Download the games that you want to play on your Pocket PC.
You can install it on your PPC using two ways:
  1. If the setup is '.exe', Connnect it to your PC thru active sync and double-click the setup file. You'll be guided thru the on-screen instructions.
  2. If it is a '.cab' file, transfer it directly to your PPC and click it to install directly.
Please rate if this solves your problem.
Jun 23, 2009 | i-mate Computers & Internet
How to make ppc windows from 2003 to 5 or 6
if you have i-mate jam , try this: http://rapidshare.com/files/257201043/HTCMAG_ROM_WWE_O3.rar
it is windos mobile 6 and It have instructions inside
Jun 07, 2009 | i-mate JAM Pocket PC
Playback on PC has no sound
Are you playing the video back through the camcorders utility ? Sometimes by clicking on the file through windows explorer you will get the picture but no sound, this happens for the Sony camcorder but is fixed by running the playback through the motion picture browser application supplied with the camcorder.
Oct 24, 2008 | JVC Everio GZ-MG360 HDD Camcorder
I-mate ppc while upgrading 'RUU172126WWE_imate' problems
here is the link to download the englinsh os
http://rapidshare.com/files/73223110/RUU_BA_xplode_WWE_6.00.00.exe
All the Best.
All the Best.
Was this solution helpful? Show your Appreciation by rating it and if your problem is solved. Please vote .. FIXYA..
Aug 10, 2008 | i-mate Pocket PC
Problem of i-mate JAQ pocket PC
I think u need to convert them in some other format like .avi .3gp .mp4 and u will find so many converters for that. and for player u can download TCPMP for pocket PC.
Feb 28, 2008 | i-mate JAQ Pocket PC
My I mate Pocket pc's camera is disabled
yes Aadil, there is a bug in the operating system and the solution is that there is a patch file you can download it from www.clubi-mate.com , it's called camera patch it will solve the problem. i solve this problem in my i-mate before...
Jul 29, 2007 | i-mate JAM Pocket PC
I-mate pocket pc phone edition
try reset with ur stylus...... take backup if possible.
Mar 25, 2007 | i-mate Pocket PC
i-mate Pocket PC Logo
224 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
