Question about HP PSC 2175 All-In-One InkJet Printer
Scanner failure I am receiving a "scanner failure" after replacing a new black cartridge. I am getting a clicking sound from inside the machine for approximately 90 seconds before it stops ... "copy", "scan" and "photo card" lights flash simultaneously. I have tries rebooting the printer but to no avail. Please help. Jim Marden yimmylee@comcast.net
  • Anonymous Feb 21, 2008
    After a power outage in our home, the hp psc 2175 came one and immediately starting making a rapid clicking noise. After about 90 seconds of this, it stopped and gave an error message on the all-in-one display screen that says, "scanner failure turn power off and on again". We did that, we also unplugged it from the surge protector and the computer, we restarted the computer, and we unplugged it and held in the right arrow key and the cancel button as we plugged it back in. Nothing has worked. We also removed the ink cartridges and unplugged and replugged the power cord in 3 times waiting 30 seconds in between. We also removed the usb cable.
    Novelist:
  • 57 Answers
I understand that you are receiving Scanner failure error.
Please follow the below given instructions to get the issue resolved.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Posted on Feb 14, 2008
  • koshkin Oct 06, 2010
    I cannot do semi-full reset. The display shows "Button is stuck, release button" but not the "S Full Reset". How I can do a reset?
HP 4015x and I get an insert black cartridge error. Not sure what I should be replacing on it or what to check on the printer.
Thank you for contacting FixYa with your printer inquiry.
This error is most common when your toner cartridge has reached it's end of life. Sometimes it will alternate with "This cartridge has reached a low threshold error" which indicates you can keep printing but need to order a new toner cartridge. See page 155 of your support manual for more on this error.
See page #117 of your user guide for toner installation instructions. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
If you have installed a new toner cartridge and receive "Remove Shipping Lock Error" that means you have not removed the protective strip on page 118 step #5.
You can order new toner cartridge from HP PartSurfer or retail merchant where printer purchased.
http://partsurfer.hp.com/Search.aspx?SearchText=CB511A CC364-67902 Black print cartridge - Prints approximately 24,000 pages per cartridge CC364-67901 Black print cartridge - Prints approximately 10,000 pages per cartridge
Hope this helps helps. Please keep us updated and remember to rate this answer.
Mar 30, 2011 | HP Laserjet P4015x Printer
Vertical blank strip
clean the roller and the cartridge head with alchol.
Jul 18, 2008 | Canon FaxPhone L75 Plain Paper Laser
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align...
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Sep 28, 2010 | HP PSC 750 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Machine won't print
Scanner failure means that the scanner bulb is no longer working. There are a few things that can sometimes bring it back but it may be a permanent issue.
1) Make sure printer is directly into the wall and not a surge protector or power strip
2) Remove cartridges from printer
3) Unplug power from back of printer and wait 30 seconds
4) While printer is unplugged press the # and 6 keys and plug power cord in. Keep holding # and 6 until the printer has either powered off or it says semi-full reset
5) Go through initialization process - if it works great the issue with firmware is fixed. If not then the scanner bulb isn't functioning and you are looking at replacing the unit.
May 11, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
CARTIAGE 50C ERROR
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
  1. Power off your All-in-One.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
May 21, 2008 | Lexmark X5150 All-In-One InkJet Printer
Refurbished Canon PC 160
Yes...it's definitely the toner cartridge.
Erice
Oct 29, 2007 | Office Equipment & Supplies
Officejet d125xi "scanner failure"
MR REPLY, BELIVE IT OR NOT. I HAD THE SAME PROBLEM .I DID THE UNTHINKABLE ,I REMOVED PRINT HEAD AND INK CATRIGAES.TOOK THE ENTIRE PRINTER IN A BATH TUB, POURED DISH WASHING SOAP ALOVER IN AND OUT, AND I WASHED IT, LIKE YOU WASH THE BABY IT COMPLETLY COVERED WITH WATER FOR 20 MIN . I THEN TOOK IT, IN THE PADIO AND DRIED 1 HOURS IN DIRECT SUNLIGHT AND IT WORKS LIKE A PRO.
Oct 03, 2007 | HP OfficeJet D125xi InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
2,068 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
