Question about LG LRFD25850 French Door Refrigerator
LG LRFC22750 Bottom freezer french door refrigerator
Our fridge is approx.2 years old. Several months ago we notice a lot of ice/frost build up at the back of the freezer running along the ice tray and top pull out tray. At the same time the fan was very loud and seemed to run all the time. We took everything out of the freezer and removed all the ice/frost build up. After doing this the fan seemed to quite down and everything seemed ok. Now less than 2 months later,there is frost building up in the back of the freezer again and everytime you open up the top doors the fan sounds like it is winding down. We do not have the ice maker hooked up at this time. Another problem is the "latch" on the top of the right door broke off completely and when we contacted the store we purchased the fridge from they said it wasn't under warranty and they would charge $78.00 just to come out and look at it. They also referred us to a local service rep, but we haven't contacted them yet. The owners manual doesn't say anything about defrosting the freezer or what may be causing this problem. I am thinking this expensive fridge is a very poor design and we wasted a lot of money on it. Any solutions to this problem?
Thank you
Tammy
  • 2 more comments
  • tammylb Feb 13, 2008
    Thanks for the info.We have the digital thermostat set to what the owners manual suggests. The freezer is set at 0. Are you saying we raise it to above 0?
  • Anonymous May 24, 2008
    we are also experiencing the exact same problem- a loud noise like a loose bearing and ice build up on our 22 cu lg fridge. We cleaned out the ice and changed the settings and will post back if that helps
  • Anonymous Jun 05, 2008
    Have LG22850TT and purchased late 11/2006 from Best Buy with 3 yr extened warranty. After ~18 months compressor fan started making noise like bearing, excessive frost buildup on freezer and fan never cuts off. Called Best Buy and they will be out in 2 days to fix under warranty. Normally don't buy warranty but in this case may be best decision ever made.
  • tmack1 Jun 09, 2008
    We also have had our Lg refrigerator for approx. 2 years, within the first couple of months the frost built up in the back and we had to have a repair man come to replace the fan motor and electronic parts as they burned out. Now here we are 18 months later and it got very loud then went down again. The repair man has had to order yet a new part supposedly one made different and better for this particular problem, also our clip on the top right door has broken off and we were given a quote of over $100 to fix it. We paid alot for this LG LRFC22750 and had high hopes. How sad that our old 25 year old refrigerator was more reliable and worked better than this expensive piece of disappointment. LG Company is no help and has no answers. They actually say they have no problems with this.
    Champion:
  • 210 Answers
LG LRFC22750 Bottom freezer french door refrigerat - 6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Posted on May 31, 2008
Same problem. 22 cf Kenmore refrig. mfg by lg Electronics. Ice forms in the rear of the freezer. Sears service said there are no known prob. referencing to this. Also a Noise that sounds lik a fan with bad bearing when compressor is running. I turned the thermostasts down to 37 and 5 asyou said. Now the fan noise happens only now and the and not all the time
Posted on Feb 15, 2008
Yes the units are in F. I'll try changing the setting to 5 F and see if that helps. We keep our house around 67.
Posted on Feb 13, 2008
  • 958 Answers
If it will take 2 months to frost back again then it could be just the thermostat. try to decrease the number setting of your thermostat after you defrosted it again . do what you did 2 months ago then when you turn it on, lower the number setting on the thermostats dial. if you have ial thermostats. if you have digital thermostats then increase the numbers settings. then observe if the compressor would stop and run now. that should minimize the frost build up at the back of the freezer section. if it will still freeze up, replace the thermostats.
  • francis rivero Feb 13, 2008
    yes please .i pressume the units are in F. if you can use the freezer with a setting of 5 F then it might do the trick. may i ask what is your room temperature?. frosting is also affected by room temp. also, check the door gasket for some damages..warm air causes frost accumulation also.
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
My freezer is producing a lot of ice. There is buildup on the side racks, making it difficult to push/pull the top drawer. There is also frost/ice build up on the back of freezer and bottom floor. I...
This always happens when you don't have 'FROST-FREE' refrigerator. Unplug the power cord or switch off the freezer for about one hour or more when lots of frost stacks (maybe weekly). Turn down the cold lavel to 2-3 instead of higher if there are not so many items in the freezer.
Nov 12, 2010 | LG LFD22860 Bottom Freezer French Door...
Frost on back wall of freezer
There is a door that is not closing 100% of the time. There is warm moist air entering the fridge and building up on the back wall.
Make sure all doors are closing. Sometime the bottom door will close on one side but not the other.
Good Luck.
Jul 24, 2010 | LG LFX25960 Bottom Freezer French Door...
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
LG LRFD25850 French Door Refrigerator Logo
1,145 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
