Question about JVC RX-778V
Mute auto I cannot get audio, the auto mute is on, do I need a remote to turn off.
I had same problem and connected antenna to fm port and it worked
Posted on Jan 07, 2009
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
Technics SU-G90 reciever is on mute with no remote i dont know how it got on mute so i dont know how to turn it off
I can't find the manual but to operate certain basic functions like Power or Mute w/o a remote you walk over to it and manually operate the Power (Off/On) or turn the volume knob UP to defeat the Mute.
For a new remote:
substitute... $39 plus shipping
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=SUG90&brand_pn=TECHNICS_SUG90&mode=large&uuid=A13127564179231
or
close to original... $18 (bidding)
http://cgi.ebay.com/Technics-remote-RAK-SA501P1-/160631869703?pt=Receivers_Tuners&hash=item256667d107
Aug 07, 2011 | Technics Audio Players & Recorders
I pushed a button and lost all sound, what should i do? is there a reset button to get going again?
The "MUTE" function on your remote control has been activated.To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office.
Dec 16, 2010 | Yamaha HTR-5930 Receiver
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
No sound in FM radio
I had same problom and fixed by connecting an antenna to fm port
Jul 05, 2008 | JVC RX-6030V Receiver
JVC STERIO RECIEVER MODEL RX-554VBX
on remote try to un mute it is a ch only on not a and b or none use a ch only go in main menu of system cheak auto mute turn off
Jan 30, 2008 | Audio Players & Recorders
Alpine pkg-1000
Hello alpine_freak, You can disconnect power from the unit and this will kill the power feed to the system memory (the memory that hold commands from the remote)Now if this does not work I have seen where the unit indicated mute as a response rather than an actuator of an event. This is rare but it does happen. What could cause this is if the audio pre-amp goes out or is turned off by the mute button and there is no sound the unit detects this and indicates a mute. This I hope is not what is happening here, because this is a design flaw, the mute should turn off the pre amp and indicate a mute condition because the mute button was pushed, not indicate mute because of a no-audio condition. As said try to remove power from the unit and if this does not work, I would suggest finding a shop on fixya to take or ship your unit to for repair
Aug 24, 2007 | Venturer PVS1950D Car DVD Player
JVC RX-778V Logo
561 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
