Samsung DLP HL-P5663W 56" TV
Problem for Samsung DLP HL-P5663W 56" TV
Samsung DLP TV HL-R5667W shuts off intermittently
By flwip on Feb 13, 2008
In 2 years the lamp has been replaced twice for the same issue. however, since the lamp was just replaced again 2 months ago and i am reading that the shutting off problem seems to be common, i wonder if the lamp is the issue at all. the TV indicator lights do not indicate overheating or that the lamp is a problem. anyone have any idea how to fix this problem or what the cause is? the TV shuts down with no warning. sometimes we can immediately turn it back on or sometimes not. the fan seems to be running fine.
Comments:
Feb 13, 2008
- thanks mike! i wrote a whole response and then clicked the rating above and apparently lost the response. here goes again -
ventilation is not the issue. the set is not in a cabinet and has great air flow. the lamp, though replaced twice, is also probably not the problem. something else, like the ballast you pointed out, must be causing the problem. samsung had me reset the tv but that didn't do anything. samsung/best buy are sending out a tech, who is going to take the tv to their shop. this new tech thinks it may be a board that costs $800-900 to replace. luckily we have a 4 year extended warranty or this set would have cost us a bundle while trying to get it fixed. the former tech really had no clue and kept replacing lamps, which is clearly not the issue. Thanks, Mike
Same Problem
Dec 22, 2008
-   My tv has know a green tint to all the people faces
What is the issue? -   Guest
Apr 27, 2008
-   My Samsung HL-P6163W DLP began shutting off for no reason after placing it in a entertainment center. The TV never gave me any idications that it was overheating. This began to occur every time I turned the TV on and would turn off 8-10 times in 20 minutes. I had the lamp replaced and it did not fix the problem. I removed my TV from the entertainment center and the TV would never shut off. It was obviously a circulation problem with the heat not getting out of the TV. I spent $5.00 on a used 110V computer fan and hot glued the fan to the rear of the vent to the left of the lamp door. I plugged the fan into my cable box to turn on with the box. I have never had a problem since. The TV has never turned off since installing the fan and it is back in my entertainment center. If you need help or pictures or fan Ideas send me an email. johnlake@comcast.net-   John Lake
Best Solution
posted on Feb 13, 2008
Helpful)
MikeMaierTV
Rank: Guru
Rating: 88%, 162 votes
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Was this helpful?
Yes
No
Popular Solutions for Samsung DLP HL-P5663W 56" TV
Questions and Unsolved Problems for Samsung DLP HL-P5663W 56" TV
Do you recommend Samsung DLP HL-P5663W 56" TV?
Answer
Answer
dog sat on tv remote and all 3 lights on tv blink and no picture and no sound
Answer
50" samsung dlp replaced lamp power on comes on normally and shuts down after minutes with all... (More)
Answer
picture but it is all different colors with vertical and horizontal lines that are all green or... (More)
Answer
How do I replace the ballast on an HLP5663wx/xaa
Answer
white distortion in picture of samsung dlp tv after tv is on for while
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung DLP HL-P5663W 56" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
