My computer does not always recognize that I have My Book connected when indeed it does. I have the USB cable in the proper port. Sometimes when it does show it is connected I still can't get to the data on my external drive. It says it isn't there. Also, I did not receive a user manuel in with the purchase of my WD 320.
Plz change usb port or if another port is not available then
change it's usb driver with appropriate driver
Posted on Feb 15, 2008
  • 20 Answers
Thr is problm wid USB driver that it alwaz loose connectivity if left unused fr long period.. try connecting with another peripheral..
Posted on Feb 14, 2008
  • SUNNY SONI
    SUNNY SONI Feb 14, 2008
    nsorry nt USB driver it is actly USB cable
    Sergeant:
    Champion:
  • 326 Answers
"Not always" means that it does work sometimes. If so, look to cable or connection.
When i try to download photos from my nikon d5000 they don,t show up on my computer
1. Your computer must have a software (eg: picture viewer) to show you the pictures.
2. When you connect the camera to the computer, the computer should show camera storage as another storeage divice under my computer. if it is not appearing then the camera is not recognized by the computer..
Oct 04, 2010 | Nikon D5000 Digital Camera
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My external hard drive wont conect to my computer.
Is this a new drive? has it worked before? the usual sequence is to connect the external drive to a power source first, and then connect the usb cables to the PC. IF you know the usb cables are good and have verified that they are connected properly, try connect to a different usb port on the PC, sometimes ports go bad. If that still doesn't work, the most likely the hard drive has gone bad.
Oct 03, 2009 | Computers & Internet
Pc doesnt detect/read portable HDD, but a USB connection appears on the task bar
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Sep 05, 2009 | Toshiba 120GB USB 2.0 Portable External...
My mac won't recognize my wd hd anymore
Aug 31, 2009 | Western Digital My Book Essential 500GB...
Computer wont recognize my e book...it was working fine last nigh
Aug 30, 2009 | Western Digital My Book Home 320GB...
Hi, I have an external disk connected to an usb port. Sometimes my computer stop to recognize the connection and my external disk doesn´t works anymore, until the next reboot. What can I do to resolve...
The only other solution other than rebooting is to remove the cable from the usb port and reinsert it. Sometimes the computer will recognize the drive and it will work properly.
Aug 13, 2009 | Microsoft Windows XP Professional SP3 Full...
Computer does not recognize it
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
Cannot connect to computer
FIRST OF ALL, NEVER EVER PLUG IT INTO THE COMPUTER WHILE ITS ON. ALWAYS TURN THE PHONE OFF BEFORE HAND. AS FAR AS YOUR COMPUTER NOT RECOGNIZING THE USB CABLE, IT MAY ACTUALLY BE YOUR COMPUTER. AFTER ALL IF IT WAS THE CABLE, YOUR PHONE WOULDN'T CHARGE SINCE IT IS THE SAME CABLE FOR CHARGING AND USB CONNECTIONS. MY COMPUTER HAS HAD TROUBLE SEVERAL TIMES WHEN PLUGGING IN NEW OR DIFFERENT DEVICES INTO THE PORT. TO CHECK THE USB PORT ON YOUR COMPUTER.... GO TO CONTROL PANEL, THEN DEVICE MANAGER. DOUBLE CLICK UNIVERSAL SERIAL BUS CONTROLLERS. IF ANY OF THEM ARENT WORKING PROPERLY THERE WILL BE A YELLOW TRIANGLE WITH AN EXCLAMTION POINT BESIDE THE UNFUNCTIONING USB. IF IT IS NOT FUNCTIONING YOU WILL HAVE TO UPDATE THE DRIVER. IF YOUR PORTS, DRIVERS ETC DONT SHOW THE YELLOW TRIANGLE, THEY ARE WORKING. TRY PLUGGING THE PHONE INTO A DIFFERENT PORT UNTIL YOU FIND ONE THAT WILL ACCEPT IT. I HAVE A LAPTOP AND MY PHONE ISNT RECOGNIZED IN THE SAME USB PORT (ON THE RIGHT SIDE OF THE COMPUTER) THAT I USE FOR MY PRINTER. I USE A DIFFERENT PORT FOR MY CELL PHONE. IF YOUR COMPUTER IS OLDER , THE USB PORT MAY NOT BE HIGH SPEED. OLDER COMPUTERS HAVE USB PORTS WITH A SPEED OF 1x OR A MIX OF PORTS WITH 1x AND 2.O (2.0 IS HIGHSPEED 1x IS NOT). I HOPE THIS HELPS!!!
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't connect EM500 to my laptop computer
It sounds like you are using two different types of USB connections, one for the iPAQ and the other for the Casio. What operating system is running on the laptop? How many USB ports are there? You might have to reboot when you want to change from one USB connector to the other. If you have two USB ports, always connecting a USB connect to the same port (iPAQ #1, Casio #2) might help the OS keep track of what is connected to it.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Computers & Internet Logo
Alun Cox
David Payne
David Payne
