Question about Sony VAIO VGN-T270P/L PC Notebook
Upgrade ram Hi! I wanted to upgrade the RAM for my Sony VGN-T27. However, I have difficulty in opening the casing. Is there a service manual for it? Thank you
  • Sony Master
  • 19,396 Answers
If you need them you can find the schematics for the VGN-T27 here : http://www.printcopy.info/shop_e/download.php?brand=Sony&prefix=VGN
Posted on Feb 13, 2008
How to upgrade SONY VAIO VGN-B3VP RAM?
call sony europe first and verify if you can still upgrade the memory/RAM..
make sure that you use the same type of RAM before you upgrade it..
goodluckü
Mar 11, 2010 | Sony VAIO VGN-B3VP Notebook
I need to desassemble my Vaio T-350P, to change the memory Tks Ricardo
if you are just upgrading ram, there will be no need to disassemble the whole machine, there should be a cover on the bottom of the machine that you will need to take off before you get access to the ram.
before you do this, make sure your machine is totally switched off, and the battery pack is removed,
try to get a service manual first before you attempt any upgrade
Sep 26, 2009 | Sony VAIO VGN-T350 Notebook
I want to upgrade my sony vaio VGN-AX570G to 4GB of RAM. I have been able to upgrade to 3GB but I want to use 4GB. Can anyone figure out my solution?
Hello!
I've checked the Sony website and it says the maximum amount of RAM you can put in the VGN-AX570G is 2GB.
I'm not sure why you are able to have 3GB, but it may be a fluke. It may be showing the memory but is not able to actually use the full 3GB.
Good luck! Make sure to rate any solutions you get!
Aug 08, 2009 | Sony Computers & Internet
Upgradation of Vaio VGN-CR23G
Hello mrsaurabhsha,
These are the types of harddrives you wnat to look at. You should also be able to upgarde from a 5400 rpm drive to a 7200 rpm drive and notice a pretty large increase in response time.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=notebook+hard+drive+sata
And please use this link to find what kind and how much RAM you can upgrade to.
http://www.crucial.com/systemscanner/index.aspx
and here is a link for them RAM
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pc2-5300+laptop
Good luck
Jul 10, 2009 | Sony VAIO VGN-CR220E/P Notebook
Need disassembly instructions to install additional RAM
If the ram is upgradeable, there should be an access port on the bottom that can easily be removed. Open all access ports until you find the one for ram. Then you should be able to upgrade the ram.
May 31, 2009 | Sony VAIO VGN-NR110E/W Notebook
I'm upgrading my memory
This is directly from the Sony site. Don't know how many pins there are, but if you order the PC2-4200 memory, it will work. Keep in mind that your computer will only accept up to 2gb.
Type: DDR2
Installed: 2GB PC2-4200 (1GBx2)
Maximum: 2GB
Speed: 533MHz
Don't k
Mar 18, 2009 | Computers & Internet
How to RAM upgrade sony vaio BZ
just open the back side...not fully ...look for 4-5 screw tightened a cover open that..there u can replace exactly like before...
Dec 04, 2008 | Sony VAIO VGN-BZ560P22 PC Notebook
Sony Vaio VGN CR-220E
Haha!
I had such dreams too with one of my old Vaio. I really wanted to upgrade the processor and graphic chipset. Turns out that the latter is impossible (it was soldered to the motherboard - it wasn't a graphics card, just an all-in-one chip), as for the processor I was able to take it out but I ran into several problems:
1) vaio added electronic components to the motherboard that made higher CPU speeds unachievable even if the motherboard's cipset (VIA) was able to do that.
2) the cpu maker (AMD in my case) kept telling me that their mobile cpu were custom designed for that specific laptop, so new cpu would be incompatible. Also mobile CPUs are, apparently, only sold to laptop makers, unlike OEMs... (eBay but at ur own risk!).
3) When buying a new CPU, u need to check factors such as the number of pins (mobile cpu are much smaller), voltage, current, wattage and heat dissipation (very important, ur current heat sink was designed for ur current cpu).
But maybe things have changed now. In my case, I could only upgrade the RAM and the hard-drive to larger and faster versions, and the difference was quite significant difference. Faster booting and better internet experience.
May 03, 2008 | Sony VAIO VGN-220E/B Notebook
Ram upgrade
No, it will only accept up to 2GB (two 1GB chips)
As for the Vaio, it seems there is only one processor available for this system and it can be seen here
http://product.pelltechnology.com/Sony_Vaio_VGN-FS840W_CPU_Replacement.asp
MOST of the time, it is not practical to upgrade a laptop since it costs so much more in parts and labor than a desktop does.
Apr 24, 2008 | Sony VAIO VGN-FS840/W Notebook
Sony VAIO VGN-T270P/L PC Notebook Logo
144 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
