Print shop 22 compatibility with Vista program
Can you tell me where to get update to allow my print shop to work on Vista?
  • 1 more comment
  • Anonymous Mar 08, 2008
    Print Shop makes my CD/DVD drive inoperable.
  • vwrodder Apr 28, 2008
    When I want an image from 'ART " It ask for program disc and for me to click OK, BUT, nothing happens. I end up using something that I can get offline. I am very dis-pleased with this. This is a new "e-machine with vista" Need help in Mississippi
  • Anonymous Mar 17, 2009
    same!
Http://support.encoreusa.com/kb.asp?id=571
Follow this.
Posted on Mar 28, 2009
    Genius:
  • 1,011 Answers
Hello sir
try this site http://www.broderbund.com/
cheers!!!!
Posted on Feb 13, 2008
I HAVE WINDOWS VISTA AND IT DOES NOT INSTAL ON MY COMPUTER
Print Shop 22 is not compatible with Vista (or Windows 7): this is the official Microsoft position.
https://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?type=Software&s=The%20Print%20Shop%2022%20Pro%20Publisher%20Deluxe
Basically, you need to get a 'free' upgrade if you bought the product as the program will also not work in 'Windows XP' compatibility mode.
If you are technically inclined, you could install a 'Virtual Machine' (such as the free Oracle VirtualBox) and install Windows XP under it: this should permit you run PS22 in the virtual machine.
Hope it helps.
Sep 21, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Hello, I had windows XP and now have Vista. I am
You need to run the installation in compatibility mode. This will allow the software to work virtually in a lower OS like Windows XP.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Jun 29, 2011 | HP Computers & Internet
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
May 25, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
Apr 09, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Will printshop version 22 work with windows7
Hi mfolkart,
Print Shop 22 is compatible with Windows 98 / 2000 / Me / XP
Not sure if Vista or 7 will run it.
Hope this helps...
Dec 29, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Printshop deluxe 22 compatibility with vista
It should install O.K. I have it on my PC with VISTA. You may have to "run as administrator". It will tell you when it trys to install. For sure PS 23 works on VIsta....
Good Luck. . . .
Nov 26, 2010 | Broderbund The Print Shop Deluxe Version...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I use Windows 7 and the PrintShop Deluxe 22 will not work.
Microsoft's Windows 7 compatibility list shows this product as unknown at this time and recommends using the Vista compatible version. If you need to upgrade to the Vista compatible version there is a free update located at the link below.
http://na6.salesforce.com/_ui/selfservice/pkb/PublicKnowledgeSolution/d?orgId=00D80000000LhUC&id=50180000000AG17&retURL=%2Fsol%2Fpublic%2Fsolutionbrowser.jsp%3Fsearch%3Dprintshop%26cid%3D02n800000009un5%26orgId%3D00D80000000LhUC%26t%3D4&ps=1
May 30, 2010 | Broderbund The Print Shop 22 Deluxe Full...
I am fairly new to PCs. I recently purchased a Toshiba 205 and have Vista SP1.  I purchase Print Shop Delux 22 and started the installation process before I read the statement about don't start...
Hello, Encore Software has released a patch to make Print Shop Deluxe 22 compatible on Windows Vista.
Here is what they say here:
http://support.encoreusa.com/kb.asp?id=571
Problem I am looking for the Vista compatibility patch. Solution This Windows® Vista update will detect and repair The Print Shop® 22 and PrintMaster® 17 applications already installed on your computer. After applying this update The Print Shop® 22 and PrintMaster® 17 will operate normally on computers running Windows® Vista.
Update Instructions
1. Click the link located at the bottom of this page.
Note: For Microsoft® Internet Explorer® the File download dialog may appear. Select Save this program to disk and click OK.
2. Choose a location (e.g., the Desktop) and click Save. The download process will begin.
3. When the download is complete, close the Download window.
4. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update.
5. Follow the onscreen instructions to complete the installation.
Note: Depending on system or user account settings, you may encounter several interruptions during the installation process. If so, please click Continue or Allow in order to proceed.
6. Launch and use The PrintShop® 22 or PrintMaster® 17.
Click here to download Broderbund_Print_Update.exe (26.7 MB)
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
548 people viewed this question
Alun Cox
David Payne
David Payne
