Dual Monitor Color/Brightness Differences
I use a Dell Vostro 1700 laptop 17" wide screen (with Windows Vista Business) as my computer for work, i dual screen it with a Dell 2005FPW flat panel lcd monitor. The problem is the color settings, and brightness on the lcd are beautiful, never cause eye strain or anything. But the laptop is horrible, its too bright and way to difficult to adjust. I tried but i just made it worse. The laptop came with a 128mb Nvidia GeForce 8400M GS graphics card.
I did notice that the lcd is 1680x1050 Resolution, but the laptop only goes to 1440x900. Could that be the difference?
Is there any way to get the settings on the laptop screen to match the pretty monitor?
Please help my eyes!
  • 178 Answers
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Posted on Feb 13, 2008
How to reduce brightness of dell vostro 1015
not sure if this will help you...
  1. Bright LCD displays under low-light conditions can strain the eyes. ...
  2. Hold the "Fn" key and press the up or down arrows to increase or reduce brightness on most Dell laptops. ...
  3. Right-click the power icon in your Windows 7 system tray and select "Adjust Screen Brightness."
How to Adjust Dell Laptop Screen Brightness ' Chron.com
smallbusiness.chron.com/adjust-dell-laptop-screen-brightness-53143.html...or try this link. How to reduce brightness of dell vostro 1015 Google Search
Oct 21, 2017 | Dell Computers & Internet
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 13, 2012 | Dell Vostro 1700 Notebook
This morning my vostro 1720 screen has taken on a blue tint and can not be lightened with FN and up arrow. What now??
Connect any external monitor and please check the display there. If the display is same then restart in safe mode and reinstal the graphics and set the brightness.
Otherwise the panel is faulty and needs to be replaced.
thanks.
Apr 08, 2010 | Dell Vostro 1700 Notebook
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
Dell Vostro 1700 Microphone
got to start,my computer,device manager, hardware and make sure that your microphone is on. Probably on mute.
Jan 08, 2009 | Dell Vostro 1700 Notebook
I can't reinstall Windows Vista for Dell Vostro 1700
my e-mail address is ihab2009@live.se add me to your msn will take u throw et i have same problem
Jan 03, 2009 | Dell Vostro 1700 Notebook
Dell Inspirion 1521 Laptop Microphone Wont Work
checklist:
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Dec 15, 2008 | Dell Inspiron 1521 Notebook
Computers & Internet Logo
1,050 people viewed this question
Alun Cox
David Payne
David Payne
