Question about Durabrand DVD-1002 DVD Player
DVD-RW COULD NOT BE PLAYED
Hi, I am trying to write movies in DVD-Re-writables, but none are able to be played using this player.
Tried all possible formats for writing, all floped.
Gimme a solution to resolve this issue.
Thanks.
  • 2 more comments
  • P Samy Feb 13, 2008
    Yes i write using my comp, I use a s/w called Inter Video Win DVD...
    I get saying either "BAD DISC" or "Not supported File"
    a) USING DVD WRITER
    b) yes i am using computer
    c) intervedio win dvd software
    d) while playing i am getting bad disc
  • eroubik Aug 31, 2008
    My dvd player will play rw's until I delete and re-record - why is this?
  • Nick Chapman
    Nick Chapman May 11, 2010
    *i realize this is an old post*
    i think the question was what software are you using to burn your dvd video disc?
    when burning, make sure you are checking to 'finalize disc' if given the option...most DVD Videos have to be finalized in order to be properly viewed -- especially on standalone players, but possibly on computers as well.
  • 178 Answers
How are you burning the dvds?
Are you using your computer?
What program are you using?
I
Posted on Feb 13, 2008
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Mine is Sony DVD player..I insert a disc and it says "CAN NOT PLAY THE DISC" and then the player shuts off. The other DVD works fine.
HI,
Check the manuel some DVD Players do not support DVD RW or -R +R formats.When Ifirst put my burned movie in I got the message that the player cant play that format Just ignore that and advance the Video to where the movie is starting then all my burned movies played fine. My Pioneer BD 51 FD does support DVD RW +R -R formats so be sure that you can play burned DVD RW +R -R on your Sony player. I was in Wal Mart the other day and they had some DVD players on sale but on the box it said that they do not play DVD RW +R or -R Burned DVD's so be careful if you do buy another one I went to best buy and found mine. Check first it will save a lot of hassle later. This software works great but it may not play in your DVD Sony Player there is a list here of compatible DVD Players
OR
your disc is scratched or a pirated one
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Sony Televison & Video
Will not rad disc, sho no disc when there is one in.
try to update your device driver (dvd player) or you must also be missing a codec to play dvvd movies.
download this codec at
http://www.free-codecs.com/download/k_lite_Mega_Codec_Pack.htm
Jun 12, 2008 | Philips DVDRW 416K (DVDRW416K/00) DVD+RW...
My burner isn't burning DVDs properly!
Try a different brand of DVD and use a lens cleaner it just may need a clean up.
Nov 29, 2006 | Lite On (SOHW-1693S) DVD±RW Dual...
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Durabrand DVD-1002 DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
