The thread that is threaded through the needle and goes down into the bobbin bed to pick up the bobbin thread, is not able to pick up the bobbin thread.
The thread does not connect with the bobbin thread.
Make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
You may have a) your needle in backwards, flat side to the front, side or back, check your manual; b) the bobbin thread not put in properly, i.e., counter clockwise/clockwise, whatever your manual says, or c) you are turning the knob the wrong way. Make sure the needle is pushed up as far as it can go into the holder. You may need to wiggle it a bit to get it to set properly.
