Water Drain My Kenmore elite calypso washer does not drains. Water is stored in the bottom tank and split on the grounnd, not even a drop goes into the drain pipe
  • lmughal Feb 14, 2008
    I fixed this, It is digital display machine, It timmer was stucking in raisin.
  • 178 Answers
You need a new water pump for this. It has gone out.
Posted on Feb 13, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore Elite Oasis Ht Top Load washer has a slow drip from the drain pipe. How to stop?
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
Oct 23, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite calypso washer
"Ld" indicates Long Drain: Ld flashes when the water level does not change after the drain pump is on.
depends on the following factors:
1-> the drain pipe could be longer than 8 feet
2-> the drain hose could clogged or kinked
3-> the pressure hose connection from the tub to the machine motor control could be pinched or plugged?
4-> and finally the pump might not be running well.
If you need any sort of help with the disassembling of machine tell me the exact model number and i can provide with some internal diagrams.Good luck with the machine.Please do rate my solution, also do post comments in case of further doubts.
Jan 24, 2009 | Kenmore 20172 Top Load Washer
Calypso washer has a ld error i need a couple more possibilities for resolving the issue as i have checked those already. just a list of possibles.
is the unit full of water or still have some water in it? if so this code is for a long drain. the drain pumps will get plugged up with lint and cause the failure code.
tip the unit back and take the bottom off. then you will see the pump. take off the hoses and also look inside the pump to see if it is plugged with lint and that will cause it to not drain completely.
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Dec 11, 2008 | Kenmore 22422 Top Load Washer
I have kenmore elite calypso wash motion washer and there is a flashing light the reads FL what does this mean.
flood lock you need to drain all water from machine and clean out pump somethimg cloggimg pump
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso HE washer
turn mach on spin,if you hear the pump turning normally you have a blocked sump.if the pump hums,you have a jammed pump.the pump is located under mach,tilt backwards as far as possible and remove screws on ft of access plate.once plate is removed pump will be on right side either held on by 2 clips or 4 torx screws.the 4 torx screws will split the pump in half and allow you to clean it out.the 2 clip pump cannot be split in half but you can remove the 2 hose clamps and try to remove what is jamming(you have a 50/50 chance of getting item out of this kind of pump).bail out as much water as possible,this mach will still have a huge amount of water in it even after bailing it so have some buckets handy and slowly drain from pump before removing.if there is something stuck in the sump,call a technician.lot more complicated and involves special tools and removing entire basket and u-joint assy..good luck
Sep 28, 2008 | Kenmore 22062 Top Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
