Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sound but no picture
Over the past 2 days, the picture on my Sharp was showing break up that looked like test pattern bars then it would resolve. Last night the picture went black but the sound is still fine. Remote changes channels as the audio changes each time the remote is pressed, just nothing but black picture.
Have surge protector, have antenna, have checked all connections for fit. Is it a video card failure?
  • Anonymous Sep 21, 2008
    Our Sharp is at least 3 years old, and without problems until today. Watching the telly, perfect picture, and then all of the sudden the is a wide black [with thin stripes] running on the horzontial. Have tried turning the set off and waitng for 15 minutes, without results. Is this the end? Please help.
    Chrissy
  • 579 Answers
LCD TV's ought to be very reliable but they are still having quite a lot of troubles like this. The power supllies tend to go out, however because the sound and tuner are still working here, the main supply is ok. Could be the back light has failed or the part of the power supply feeding the backlight.
The other common problem we see is bad solder joints due to the reduced performance of the new lead-free solders the makers have gone to. LCD's are pretty easy to take apart and just spend some time resoldering everything that looks suspicious. Especially the larger components.
Hope Ya Fix It.
Posted on Feb 13, 2008
    Champion:
  • 206 Answers
Sound like the main board may have died, but this set has some firmware upgrades that can be done as well, there also may be a problem with the LCD control board. At any rate this problem is beyond the backyard tv tech, my advise is to take it to a autherized Sharp repair shop, by doing that the shop can order these part through Sharps board exchange program and save you some money on the parts
I have a Sharp 60 inch ledtv (LC60LE835U). The power button flashes short/long. I used the reset code but have no picture or sound. I looked through the back panel and don't see any lights. I also used the...
You lost your backlights, common issue on this set..you will need to get into the panel and replace the strips that are bad or take it in for service
Mar 22, 2018 | Sharp Televison & Video
Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Oct 16, 2007 | Televison & Video
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
I have an jbl soundbar and a sharp hd tv. After we connected the sound bar we no longer got a picture or sound.
The two brands should be compatible, and plugging the sound bar in should not affect the picture...either the tv chose that particular moment to go bad, or you plugged the soundbar into the wrong place...look for "audio out" connectors on the tv (should be RCA connectors)...
Jan 01, 2015 | Televison & Video
Picture started getting fuzzy then it went out
yes,remove the back of the tv,on the power board you will see the problem.replace those capacitors on the power board.this will allow the set to work.the black bars may still be there.this is an indication of a bad panel.
Aug 08, 2009 | Televison & Video
Watching new two day old le37r87 and the screen just went black now does nothing but the soulnd still comes out of the Hi-fi
Does bulb come on? If not, I would take it back since only 2 days old. If it does, try unplugging for a few minutes and plugging back in to see if that solves problem. If not, you can check test patterns by getting into service mode to see if display is working. Not sure what code to get into service mode on your tv is, but I have a different model Samsung and I enter service mode by pressing "mute", "1", "8", "2", then "power" on the remote. If your samsung has same code, it will start up in service mode. Once in service mode, go to DDP1011, then Test Pattern. Go through the different patterns by pressing the right arrow key on remote. If they don't show up, you probably have bad DMD board. If they do show up, go back to main menu and select DNle then Test Pattern. If pattern does not show up, you have an analog board problem. If it does show up, go back to main menu and there should be an option in the menu tree to do a user reset, which will change everything to factory defaults and restart tv. Hope this helps. If not I would be taking it back since only 2 days old.
May 16, 2008 | Samsung Televison & Video
TV
We have perfect picture but no sound when changing channel you get a sharp noise and thats it 1 reset once 2 ptoblem in transmission 3 as noise is there so your audio section is alright. the problem is sound signal in not reaching to audio section or print break in that line or some one has mistunned sound if section coil. hope this will help.
Oct 03, 2007 | Televison & Video
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
127 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
