Question about Brother MFC-7820N Printer
Scabbubg If I try to feed more than one page into machine to scan the papers won't feed. I can only do one page at a time by placing the page on the window.
  • Vest Feb 13, 2008
    One year. I'm able to feed other documents through if I am making copies but not scanning.
  • 178 Answers
WOW. Sound like the automatic feeder needs to be checked and cleaned. How old is the printer?
Posted on Feb 13, 2008
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
Lexmark Pro901 When scanning from document feed the machine seems to scan only a part of the page whilst cutting out the information at the bottom of the page.
Make sure to set the correct paper size when scanning from the ADF. If you're scanning a legal size document, set the paper size to legal.
If it doesn't work, try to reset the printer back to its factory settings:
1 From the home screen, touch Setup (wrench icon), and then touch Use Factory Defaults.
2 Touch Yes.
3 When prompted to set the initial settings of your printer, make your selections using the touch screen.
Oct 12, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Toshiba e-studio 3510c
Check that the cable that comes out of the back of the feeder is plugged in completely. If not, turn off the machine and unplug the copier before plugging the adf connector in, then turn machine back on.
If that is not the problem, the sensor flag or sensor may be out of place. Where the paper goes in, there should be a black plastic flag hanging down that the paper will move when you insert it, If you can see it and it seems to move properly, then the sensor may be out of place or the sensor/feed medchanism is out of place and it is a little tricky to explain here. The sensor is above the flag, but under a metal plate and you may mess it up worse by trying to take it apart.
Nov 19, 2011 | Toshiba E-STUDIO 211C Copier
HP OJ 6310 - scan/fax feeder won't pull through paper for scan/fax. Have tried cleaning rollers to no avail. Can you help??
There are two types of jams.
Physical, A physical obstruction is preventing the paper from gettin through.
Timing, the paper does not reach a given piont in a given period of time.
Physical jams can be the easier of the two, look for anything out of place, check the lead edge of the paper, is it dented or damaged? if so line up the damage with the feeder open and see if you can locate the problem, it does not need to be a foriegn object, it could be a guide mylar that is damaged or out of place.
Timing are are where the original does not show any signs of damage, the machine just stops.
This can be caused by feed tires, feed motor or clutch, or sensors,
Check the condition of the rollers, rollers generally have a rippled surface, if the rollers are bald and or have become concave. they are worn out.
Clean the rollers with a rubber cleaner or alcohol, clean the paper path with alcohol, check for sticky areas, adhesives from post its or signature flags.
Clean the scan glass with a good glass cleaner.
Blow out sensors with compressed air (Computer Duster), if sensors have an actuator arm, ensure the arm is in place and moves freely.
Give this a try.
Hope it is of some help.
Ed
May 01, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 1315 paper load and scan problems
I would perform a hard reset of the printer electronics and also reinstall the driver to see if the combination of these two procedures restores proper operation.
Sep 20, 2017 | HP OfficeJet k60xi InkJet Printer
Incomplete feed
try correcting the page width and make sure one page goes through at a time also you can press the bottom of the paper and it will feed better
Mar 18, 2008 | Xerox DocuMate 252 Path-Through Scanner
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Nov 20, 2007 | Canon DR-3080CII Path-Through Flatbed...
Brother MFC-7820N Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
