Question about Refrigerators
Food centre (3yrs old) costing 1000.00 is now suffering from insulation breakdown. I argue it has to be a manufacturing fault as it is inside sealed panels and there is no damage to internal or external it is also situated as per manufacturers guidelines. Please advise
  • annknight Feb 15, 2008
    We contacted Currys repair centre when the fridge freezer started heating up. they gave us the name of their local eng who came in and diagnosed, breakdown of the fan. Also insulation breakdown within the casing. He said the fridge even if repaired would have a very short life span.
    Now trying to deal with currys as this appears to have been a manufacturing fault. Please advise
  • robert samples May 11, 2010
    what do you mean exactly by insulation breakdown
    President:
  • 1,314 Answers
Well forgive me but it sounds like hes full of manure un less he has x ray vision there is no way he can know .The fridges are foamed insulation which will be here long after we are gone why dont you tell me the symptoms you are experincing we will go from there what is the brand and model number and are you in the usa
Posted on Feb 15, 2008
Insulation breakdown
Hi.
I have not seen a subzero unit that could not be repaired, even thirty years old unit can be repaired. With that being said, I would call subzero directly to ask for a certified servicer in your area to take care of your unit. Here is a link for their website to help you Contact and Support they will get you a person knowledgeable to correct your issue. FYI not everyone can work on SubZero unit. This unit if 12 1/2 years old is just a teenager to this manufacture, no worries. They can last over 30 years, I have seen them and repaired them.
I am here if you need help in SoCal.
Jun 08, 2013 | Sub-Zero Refrigerators
Tip
Making Freezer Blocking Work
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Getting to know more about freezer blocking you have to know some steps or methods.
With the weather this is the time when people starting to put away the excess bounty of their garden. Chest freezers seem to be the answer for many gardeners. Vegetables that have not already been consumed need to be stored for use throughout the winter months.
Once you have bottled and/or packaged your vegetables they will have to be stored in a cold environment that is below their freezing point and at a low humidity level. A cold environment slows down the natural deterioration of vegetable matter that occurs. Most vegetables that are placed into a cold environment will go into a type of dormant state.
For those without the basement cold storage room an alternative is the household freezer. Many people use a small chest freezer for this purpose. An upright freezer will also work but they are not as efficient (or as cold) as the chest variety. Also the small chest freezer is generally less expensive than an upright of the same size. Basically freezer blocking is filling up the unused space inside the freezer. The theory is ... the less air inside the freezer the less electricity will be required to freeze the food. Anything that lowers the internal volume of the freezer will cause the compressor to spend less time keeping the interior cold. It would be equivalent to having a smaller freezer.
To do this cardboard boxes called "blockers" are placed inside the freezer. These boxes are filled with insulation. Any form of insulation will work, but basic household wall insulation (fiberglass) is most commonly used. It is both inexpensive and easily obtained. An alternative are the insulating peanuts used for shipping and packaging. Others suggest filling the boxes with old newspapers. This would work but the insulation value would be far less than the fibreglass method. Also the newspaper would pick up moisture and become extremely heavy to lift.
Obviously a cold storage room is the most economical method. It uses the winter temperatures to keep foods cold. Unfortunately its downside is that the temperature cannot be regulated. If the outside temperature changes so does the temperature inside the cold storage room. Also few modern homes have a cold storage room. It is considered unnecessary in today's fast paced society.
Whatever is used the boxes should be completely filled, and then sealed and taped shut. You do not want insulation mixing openly with food products. Also boxes of varied sizes work best because they allow you to fill up the open spaces better.
If the freezer is only half full then place the boxes either at the bottom of the freezer or all to one side. This way you have easier access to the food during the winter. Placing the boxes on top will be frustrating because you will have to remove them every time you want to get to the food.
Another way of doing this would be to place blankets or sleeping bags inside the open areas of the freezer. The insulation method is usually preferred though because it is much easier to move around boxes than an old sleeping bag.
An alternative method is to add containers of water to the freezer...partially full containers - remember water expands about 10% when frozen.
This is not true freezer blocking. Rather it is a method called heat sinking. Containers of water added to the freezer will themselves freeze into blocks of ice. Every time the freezer shuts off the cold stored inside the ice blocks will help keep the food frozen. The ice should slow down the natural heat transfer between the freezer walls and the food. The colder the freezer interior the less the cold control will turn on the compressor.
Although heat sinking is good in theory I am not convinced this method really saves money.
In all of the above methods the overall affect (in theory) is to make the freezer operate less. So the less it operates the less electricity it will consume. How much can be saved by these methods has not been properly tested. The best estimate is that it could save you 5% to 15% per year. I hope with this little write up you can get solution to your problems on Freezer Blocking. http://www.victorwod1234.blogspot.com
on Mar 06, 2010 | Refrigerators
Food does not get hot
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 22, 2010 | GE Profile Spacemaker Over-the-Range...
My fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Microwave runs, but food does not heat
Jan 31, 2010 | Microwave Ovens
Moved homes and took old dishwasher to new home (about 3yrs old), now seems the machine is loud (sounds like disposal is louder) all insullation is still on machine. we did go fom carpet floor to tile...
make sure your unit is secured properly[screwed up into counter and leveled], to minimise vibration. other wise you may want to try putting some insulation behind the kick plate.
Sep 18, 2009 | Dishwashers
My fridge smells terrible and I've clean out
You got some thing in the insulation...its done
Aug 19, 2009 | Frigidaire Refrigerators
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer burn on all foods when sealed by me or the manufacturer
You might need to turn the freezer temp. up a little. I think 0-10 degrees is good.
Sep 21, 2008 | Frigidaire FRS26R4A Side by Side...
Sub Zero insulation freezing
These units are pretty much manufactured, then the insulation is inserted as a liquid that forms into a solid insulation. Consider the age of the unit for a replacement IMHO.
Mar 11, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
