Konka KDL32AT23U 32 in. LCD Television Logo
Posted on Feb 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PIP i cannot get PIP on my set.
Anonymous
Level 2:
  • Expert 178 Answers
  • Posted on Feb 13, 2008
Anonymous
Expert
Level 2:
Answers
178
Questions
0
Helped
83089
Points
369
Do you have remote for the tv
There should be a PIP button on the remote
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
2answers
Pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Pip won't turn off. can the pip be removed or bypassed?
Some of the older sets with PIP require only the original remote to operate or turn on and off.
The PIP board usually develops problems with surface mounted caps and there is a "modification" where traces are cut and two 4.7 mfd caps inserted which will bypass the PIP board from the set--a model number would tell me if this is possible in your set or not--you missing the original remote? Almost any Mitsubishi remote of the era with PIP controls should do the job.
1helpful
How do i get the pip, Picture in picture to work ??
If it has the feature buttons on the remote for it, swap, position etc.
Some older sets have to have signal routed to one of the rear video inputs for a source for the PIP. Newer sets have two tuners--one for main and one for PIP---if pulled up the swap will switch one picture for the other--some allow both on the screen at same time side by side.
Read the owner manual to see if the set has PIP.
My picture in picture isn't working?
Most of these sets have two tuners--one for main and one for PIP.
If main picture works fine but PIP is bad or Green? either the PIP tuner or the PIP board is bad---these were known to have the PIP have problems but it was more rare than their sets made before it.
SD TECH
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
2answers
I have a pip on my screen. Can't remove it
somw sets you need to set up in the set-up menu what signal source is shown in the pip box. to turn it off push the pip button on the remote once
9helpful
2answers
Can't remove blue PIP (?) section in lower RH corner
I have the Olevia TV with RC-LTU remote, To get rid of PIP just press the (VIEW) button twice.
PIP
PIP active requires two seperate signal sources delivered to the tv.... set-top box is ok, split signal---give half to box,then to set via A / V cables, the other half directly to set......Did you consult
owners manual?.........T.
Top Konka Televison & Video Experts
ZJ Limited
ZJ Limited
Paul Bade
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
