Medion MD41060 Memory Installation
I want to install memory in the 2nd of 2 memory banks on this laptop, The 2nd memory bank is located under the keyboard I am told and that there are three tabs at the top of the keyboard securing it in position. I have been unable to locate these and cannot release the keyboard. Has anyone any ideas please?
Richard
  • varadero Feb 13, 2008
    Thanks for the suggestion Chandra, unfortunately, that isn't the solution. One compartment is at the back with 1 memory bank, but according to Medion, the other is under the keyboard but cannot see where to release it!
    Thanks
    Richard
  • varadero Feb 20, 2008
    Thanks Roydart, I've a sneaking feeling you are right about the access to the 2nd bank of memory. Sliding that panel to the left would make sense (taking care because the plastic looks hard and brittle as you say). I don't have the laptop in front of me, buy when I do, I'll give it a whirl. Thanks for your help
    Richard
I have a medion 41060 and the way I accessed the memory under the keyboard was as follows: Remove the battery and power supply lead for safety, slide the panel with the start button and hot buttons above the keyboard to the left very carefully. As it is plastic and very delicate it should not be forced. Under this panel are three black screws which hold the keyboard in place. Remove the screws and lift the keyboard from the top edge. The memory is below a dished panel held by three screws. You might aswell suck out the dust from your cooler fan before you replace the keyboard. Everything goes back in reverse order, but be very careful with the top panel as the lugs to it are very delicate.
I hope that I have helped,
Roydart
Posted on Feb 20, 2008
  • 108 Answers
Hey, as far as my knowledge is concerned, the battery compartment is on the backside of laptop and there is a symbol on that compartment. you just need a screw driver to open two screws and reach the RAM compartment.
Try that you will fixup your problem.
Posted on Feb 13, 2008
How to install memory
Unplug the laptop from the power supply. Remove the battery. Locate your user manual (hard copy or printed from the internet for your laptop's make and model). Now, open the bottom of the laptop, locate the memory bank and follow instructions for memory installation provided by your laptop manufacturer in the user manual.
Aug 25, 2014 | Computers & Internet
How do I install an additional RAM card
The IBM NetVista A22p has 3 memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
*2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
*3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
*4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
*8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
*12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
How do I install memory on my IBM NetVista A22p 2292-xxx?
Memory installation help guides can be found at the following link.
Memory Installation Guide
Installing DDR DDR2 DIMMs
Installing SDRAM DIMMs
Jan 11, 2011 | IBM NetVista A22p PC Desktop
I am having Intel Board SE7501BR2, i wanted to know how much RAM does it support and of what speed, because currently it is having 512 mb ram with speed of DDR$266 mhz.
This motherboard can support up to 2Gb of DDR266 RAM modules.
Attached is part of the memory detail from the manual.
If you need a copy of the manual. please click on this link to download :-
ftp://serwery.optimus.pl/Servers/Motherboards/SE7501BR2/Dokumenty/se7501br2tps.pdf
3.1.2.2 Memory Configuration
Memory interface between the MCH and DIMMs is 144 bits wide. This requires that two DIMMs
be populated per bank in order for the system to operate. At least one bank has to be populated
in order for the system to boot. If additional banks have less than two DIMMs, the memory for
that bank(s) will not be available to the system.
There are two banks of DIMMs, labeled Bank1 and Bank2. Bank1 contains DIMM locations
DIMM1A and DIMM1B and Bank2 contains DIMM2A and DIMM2B. DIMM socket identifiers are
marked with silk screen next to each DIMM socket on the baseboard. The sockets associated
with any given bank are located next to each other.
The baseboard's signal integrity is optimized when memory banks are populated in order.
Therefore, DIMM Bank1 must be populated before Bank2.
DIMM and memory configurations must adhere to the following:
• DDR266 DDR registered DIMM modules
• DIMM organization: x72 ECC
• Pin count: 184
• DIMM capacity: 128 MB, 256 MB, 512 MB, 1 GB, 2 GB
• Serial PD: JEDEC Rev 2.0
• Voltage options: 2.5 V (VDD/VDDQ)
• Interface: SSTL2
• Two DIMMs must be populated in a bank for a 144-bit wide memory data path
• One or two memory banks may be populated
Table 2. Memory Bank Labels
Memory DIMM Bank Row
J8D22 (DIMM 1A), J8D15 (DIMM 1B) 1 0, 1
J8D7 (DIMM 2A), J8D1 (DIMM 2B) 2 2, 3
Note: Memory must be installed in pairs; DIMM Bank1 must be populated before DIMM Bank2.
Memory within a DIMM bank must be identical; between banks only the DIMM size may be
different.
Functional Architecture Intel® Server Board SE7501BR2 Technical Product Specification
26 Revision 1.2
Intel Order Number C13977-003
Figure 3. Memory Bank Label Definition
Sep 25, 2010 | Intel Server Board SE7501BR2 Motherboard
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
How do i add more ram
The Toshiba Satellite A45-S150 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A45-S150 can support up to 2 individual RAM modules. Look on bottom of laptop and there will be place to take screw out and you will see the 2 modulars. Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A45-S150.
Nov 28, 2009 | Toshiba Satellite A45-S150 Notebook
Wheres the ram?
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
May 11, 2009 | Computers & Internet
How do I install ram on my medion 5200 composer
Open your pc and then find and remove the memory in the memory bank, see your computer documentation for the memory specification of your pc.
http://www.ehow.com/how_895_install-ram.html
may this help.
melnavz
Oct 25, 2008 | Medion Computers & Internet
Where are the ram chips located on balance cn 1401? i would like to upgrade my memory.hwo do i do it?
usually under the bottom of the laptop there are some covers, the memory will be under one of them. To see what to look for follow this link: http://img.zdnet.com/techDirectory/_MEMMOD.GIF To find a compatible module run the tool from crucial http://www.crucial.com/systemscanner/index.aspx
Jun 21, 2008 | Balance CN1401 Notebook
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Open Questions:
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
