Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
When I turn on the TV, power light blinks green red orange red green green red, then blinks red 3 times. does anyone know what this means???help...
  • 8 more comments
  • rickhagan1 Apr 12, 2008
    same problem, 3 blinking lights and wont turn....
  • fastvegas Jul 28, 2008
    My KDF-60XBR950 was having a problem with the LED would flash three times and then flash three times again for several times. I had a extras lamp and thought the would work. but it still did the same thing. I did check the lamp door switch and it seemed ok. but I used a pen to click it shut manually and it WORKED!!! so the door was bad in some way that made the TV not to fuction with the switch. I bent the door very slightly and it worked. Yeah!!!!!
  • n_tsai Jan 22, 2009
    the tv doesn't turn on. i can hear the fan going but then it blinks red, green, rance.. and then continually blinks 3 reds. whats wrong. it worked fine earlier today.
  • Anonymous Mar 13, 2014
    Green light blinds 6times then red light starts to blink
  • Anonymous Mar 17, 2014
    green light binks for a while then red light blinks continuely
    red light keeps blinking
  • Anonymous Mar 18, 2014
    why does my 47lg70-UA lcd tv blink red 2 times then turns on then blinks red 1 more time then turns blue and then turns off
  • Anonymous Mar 22, 2014
    my soniq tv the red light it blinks and the tv wont turn on how can I fix this
  • Anonymous Mar 27, 2014
    TV will not go on. Red blinking light 4 times in a row.
  • David chavez Feb 07, 2017
    The green blinks 3 times and the red blinks 3 times what does that mean .
Same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
I had the same problem this morning and got on this forum and read about the solution. The big part of it is how many times the red light is blinking. I took the door off and put it back on and the TV now works again. THANK YOU ALL FOR YOUR HELP YOU SAVED ME A LOT OF $$$$$$ on a service call.
Posted on Oct 12, 2008
YES!!!!!!!!! THANK YOU!!!!!!!!!!!
After replacing the lamp, my 60xbr was flashing 3 times. I pulled the cover off, and the switch plunger was bent very slightly. Almost could not see it. So I heated it with a heat gun, and bent it back. THE F-CKIN TV WORKS!!!!! THANKS AGAIN!!!!!!!!!!!!!!1
Posted on Jul 15, 2008
    Sergeant:
    Champion:
  • 301 Answers
Pull the frony off of your tv as if you were replacing the lamp (check owners manual) 3 blinks is lamp door switch. if your lamp door is melted or deformed in any way than replace door and lamp if needed. you can contact sony and order the parts yourself.
Posted on Feb 20, 2008
    New Friend:
  • 16 Answers
Lamp door error. Make sure the door is secure. A plastic tab on lamp door pushes on switch, you can hold the switch to test without replacing door. Enjoy!
Posted on Nov 04, 2013
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Green orange then red flashing 3 times light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 04, 2014 | Televison & Video
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Playstation3 cant turn on><
try turning the main swith on and off a few times, then power the front.
let me know
thx
Aug 02, 2009 | Sony Playstation 3 (PS3) Console
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
Canon pixma mp-610
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 19, 2009 | Office Equipment & Supplies
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Lost all Power to TV
My TV did the same thing today. My red light blinks 6 times. Any help would be much appreciated!
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
3,844 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
