Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Can i record from tv to dvd
I though i could recored tv shows to dvd... can i ?
  • Del Rose Apr 05, 2008
    When trying to record from TV, I get a recording error message, that states can not record from this disc and the number E454037380
    It has not always done this, and I have bought several different spindles of blank dvd's, thinking that maybe I got a bad lot. It doesn't matter, it will not record from the TV. The DVD Recorder/VCR combo is maybe 2.5 years old.
  • tomg1960 Apr 21, 2008
    cant record e 4 54037380 if you can help ??? I think that all manufacurtres have instaled shut down in the memory after a number of recordings are reached , this is the third time it happend all different dvd recorders
    Problem Solver:
  • 5 Answers
Before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Posted on Apr 27, 2008
  • 3 Answers
Yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
Posted on Feb 27, 2008
Manual recording procedure
I am assuming that is what they ment.
Because a DVD Player would not be able to Recored anything at all. And he did not mention anything about there being a VCR in it or anything about a VCR in Fact.
You would have to Have a DVD Recorder to Record anything onto DVD's
Aug 24, 2012 | Panasonic DMR-E85H DVD Recorder
My sony dvd recorder tells me my hard drive is full but it is not
try to unplug and don't use for a while to reset the dvd recorder then re plugged and turn it on again.
Jun 14, 2012 | Televison & Video
Can I recored a VCR to the DVD on this machine?without a TV?
yes, but I strongly suggest you use the screen (unless the recording is a 5 - 6 hour epic) where as you record the event and go to sleep and the devices shut off once finish.
Mar 16, 2011 | Broksonic DRVCR900 DVD Recorder/VCR
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
LiteOn DVD Recorder is not properly working
If you wish to get some details; visit the site linked here. Pull up older posts.
Sep 28, 2017 | Televison & Video
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
How do I connect my dvd recorer to my tv/sky decoder?
Dear, aragorn1nz,
Please connect the audio / video output connection of dvd recorder to the input of TV's input.
ramesh22
Jun 24, 2008 | Televison & Video
Recording does not work
Could bethat your Hard Drive is full. Make sure it isn't and if it is then try erasing some programs. Also, check the User's Guide to reset the unit (usually done by pressing a combination of buttons for about 10 seconds)
Jun 15, 2008 | LG RH266 Recorder
DVD Player/Recorder
i need help hooking up my dvd recorder to my cable box and my tv what do i need to do to recored tv programs....
May 26, 2008 | Mico DVDR311
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
191 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
