Plasma tv has developed a black stripe in the upper lefthand corner, about one foot long and one inch wide.
    Champion:
  • 206 Answers
This could be a bad thing, hopfuly only a driver board has failed and need replacment , Now for the worse case, the panel has failed. If thats the case it almost allways cost more to replace the panel than to replace the set
Posted on Feb 13, 2008
I have a jvc av-56wp74 56 in rear projection tv it has a lil purplehalf moon on upper left corner about 1 ft wide and 2 inches down and the tpo lefthand corner is lil blurry the rest of tv is fine any help...
Well David, it sounds like you need to unplug and open back and try to stick your head up in set and look down into CRT's tubes, you may have phopser damage on one of the tubes, you will need to turn on to see it just be careful not to touch anything electrical
Feb 02, 2011 | JVC AV-56WP74 56" Rear Projection...
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I have a white line about 1 inch thick and 3 inches wide on my samsung tv it is 10 months old it is on the top left hand corner
Ten months only tv,ur tv still under warrenty,call Samsung wright away.Take ur manufacture warrenty repair.The tv main Tuner signal board is developing a problems.
Oct 27, 2010 | Samsung HP-T4254 42 in. Plasma Television
Panasonic TH-50PX60U 50 in. HDTV Plasma Television. 4 years old. It has developed a 2 inch by 12 inch vertical black line bordered by intermittent red/grenn pixles in the upper right corner of the screen.
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 02, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Nakamichi Plasma VU50P black stripe
Yes all set or fixable, you will need to order the y board, or driver board this is the power supply supply the defflection to the screen. I have tried several time to try to fix them, and didn't have luck at all, just a wast of time, there waxed and most of the time can't take part's out because they also clued them.
This process is faster for them when the machine makes the board, parts don't move.
Y board just got one narmaly goes about $400 and up.
This is the reason why most people just toss out there set, and they get mad at the tech, don't know why, it's not there problem they don't make the board.
I would open the back cover to see were the smoke came from, you will see some burt mostfet's or resistors. The part # narmaly is writen on the pcb. Call them and ask them the price. You will see, why most set's or found at the grave yard.
I hope this help's
What About Bob
Feb 13, 2008 | Televison & Video
Black 3-4 inch wide Stripe
this problem is a bad panel it needs to be replaced in some cases the panel is under warranty. check your warranty.
also the E and F buffers could be at fault I would have these replaced first.
Oct 14, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
