Question about Creda W120VW Front Load Washer
Creda excel 1200
When i turn on the washer then water starts to fill then streams out under the draw. i have checked pump not blocked. ahave cleaned the draw too.
any ideas welcome.
  • 178 Answers
Have you checked the dishcharge hose inside. Sound like you might have a break in the line somewhere.
Posted on Feb 13, 2008
Fabric drawer section fills with water after every wash
the siphon cap in the fab con section of the draw is blocked the water is drained away by using a siphon remove the draw from the machine you should see a up-stand with a removable cap on it take it of and clean all the gunge out
Feb 26, 2014 | Creda Washing Machines
Can my creda excel 1200 be converted to fill with hot water instead of cold water
Unfortunately it will need cold water for the rinses. Also it controls the temperature of the (hot) water itself which it would not be able to do if fed with water that was too hot- for delicates for instance ;-0(
To use your hot water would require a hot AND cold fill washer, sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Creda Washing Machines
My pressure washer will not pump the soap, when you take the pipe loose from the handle it pumps out when you hook it back to the handle it quites pumping
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
Sep 02, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
I have a creda excel 1200 the other day the water started to come out of the door and it tripped the electric,anyway i now managed to drain some of the water out of the machine but now its still tripping...
Remove back from machine, dissconnect motor plug from motor, then turn machine on, if electric trips then you know motor is ok so place plug back into it, then do pump, and so on untile something is disconnected and fuse wont trip. Make sure you do not have machine connected to power supply while removing wires, also that wires do not come into contact with anything when disconnected. And dont remove Any earth wires
Feb 11, 2010 | Creda W120VW Front Load Washer
Windshiels washer worked yesterday but not to
Check for airlock on pump input (if pump not mounted below water tank level),
check water delivery at pump outup port is ok,
check for kinked/crushed delivery hose,
check for blocked squirter nozzles.
Oct 17, 2009 | 1999 Isuzu Rodeo
My washer does not empty
i had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Jun 17, 2009 | Creda W100FW Front Load Washer
Creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Apr 17, 2008 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
222 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
