Question about Maytag Performa PAV2200
PAV2200 WASHER WILL NOT SPIN
It makes a sound on spin, but does not move.
  • digiwash Mar 16, 2008
    After the washer fills with water and starts the wash cycle, it makes a lot noise and doesn't agitate. However, it looks like its trying. Please help.
  • 240 Answers
Sounds like the brake assembly or transmission drive pully has went bad. Problem is, that brake assembly must be done by a qualified repair-person because it is strong spring loaded and will cause major injury if you dont use a special tool to remove it. Parts are not that expensive, and should take long to repair.
Posted on Feb 14, 2008
Maytag Performa PAV2200 makes a rumbling sound while agetating. Suspect a worn bearing or belt? Could you shed any light on this?
Yes it could be the spin bearing at the base on top of the brake assembly. I would suspect that the brake assembly is the cause of the noise as this engaged when you the washer agitates. If it was the bearing it would make a loud noise in the spin cycle, too.
Nov 05, 2009 | Maytag Performa PAV2200
Spin cycle
sounds like a bra wire caught in drum
Jun 23, 2009 | Maytag Performa PAV2200
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Maytag Performa PAV2000AWW
yes it sounds like a timer fault
Aug 27, 2008 | Maytag Performa PAV2200
Washer makes loud scraping sound
Could very well be the pump as well. These pumps have been notoriously bad for the pully shaft housing slipping down and hitting the pump pully. More that likely your problem.
Jul 31, 2008 | Maytag Performa PAV2200
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Washing Machines Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
