I am trying to connect my PC to my Plasma TV. I have conected the 15 pin screw fix monitor cable to both but I am getting a blank screen? I even changed the sttingsto PC but still nothng other thanthe words PC just
when you say you have even changed the settings to pc...do you mean you have used PC..to try connect...through settings..??
I would have thought on the remote there is a button for setting up the Plasma TV? you checked to make sure there isn't a menu where you can tell the TV its connected to a PC??
It may be you will have to switch between the two. My reason is that on my TFT..there is a menu....when I check the list..there is an option to connect to PC..AV1 AV2.
With your lead connected you should get something?
hope helps
Was this solution helpful? Show your Appreciation by rating it:
