Back to:
Tags:
Tasco 750 Monocular Microscope
Optic lens tube separation
posted by jlanghus on Feb 13, 2008
We have 20 monocular Leica BME scopes. Several of them have had the tube that holds the optic lens separate from the rotatable head of the microscope. What is left is a black fitting with a square glass peice in the bottom. Is this a friction fit or a glued joint? They are very loose and no longer snug up. Would you suggest a glue that can be used or is there a better fix to this problem?
Jim Langhus
langhusjd@mflmarmac.k12.ia.us
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 19, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
sir,your microscope tube with the eye piece is screw joint with microscope body. Rather part is friction fitted as well as there is a proper place to mount it.you can do the gluing but first of all be clear that part should be not a movebale part other wise you will have dificulty for fine focusing.
for the further quotation dont be hazitate,
INDRAVIJAY
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Optic lens tube separation:
I don't want to Accept this solution
Solution #2
posted on Mar 10, 2008
Not Rated (0)
Dave Duff
Rank:Master Master
Rating: 90%, 15 votes
Hi There,
I understand your problem and I would
Recommend stud-fix by Loctite, making as sure as possible that the tube occupies the exact same place as it did before removal (at right angles to the optical axis)
If I can be of further assistance, please do not hesitate to contact me.
Regards….Dave
Thank You!
Solution #3
posted on Feb 14, 2008
Not Rated (0)
jlanghus
Rating: 0%, 0 votes
The tube joint was a friction fit that had become loose. Most of the time it is a screw joint which is why I was confused. We put some electrical tape around the inside portion of the fitting and the tube fit snugly down over it. We'll have to wait and see how long it lasts.
Jlanghus
Thank You!
Can you Help with these Microscopes problems?
where can I find a manual for a kids Tasco 80X-1200X Zoom...
Microscopes
I replaced an old (failed - hours used up ?) mercury arc...
Microscopes
field does not change as mechanical stage is moved
Microscopes
I have lost the processing software CD for Galileo Mars...
Microscopes
My Vivitar 900x 28-piece microscope set (WIC#552844...
Loading problems.
Repair Service
Find Microscope Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
