Question about Dell Dimension 8400 PC Desktop
Frozen My system as the Raid system. One day asked to restart to finish updates. Well the system has not completed the boot up sequence yet. It is stuck at the Dell Logo screen and it has not made it pass that yet. Trying a new Sata hard drive did not help. It is locked up I did hear the system make more noise than it has since it's been broken. the CD drives are moving now but the power switch is lit but the power activitiy light is not lite up.
  • 145 Answers
Try disconnecting the power and resetting the CMOS. Sometimes there are 3 pins on the motherboard by the battery, change the jumper to reset, and restart the system. If there are no jumpers to reset CMOS simply remove the battery for about 1 minute then replace, and try booting again. I suspect windows won't actually boot, and if it doesnt restart and press F8 before windows attempts to load. This will take you to the boot manager where you should choose last known working configuration.
Posted on Feb 13, 2008
HP TouchSmart IQ518a Desktop PC cannot boot up after Blue Screen Error
check the ram memory if it restarting in a loop ..when it gives memory blue screen is not referring on hard disk only ..it may be teh ram memory as well ..and if it had errors it is probably something wrong with the way you installed or the partitions you have ..You need a large C drive partition made for windows & ..at least 50 G and you need to format it when you install so that it is clean and functional ..If you installed over another OS..or not formatted it or it is too small ..even if you have space in other partitions this is not a solution ..You need to have space in C drive where the windows works ..
Other issues ... maybe is a file missing and does not let it boot or ..you made changes in BIOS .. for example if you installed the OS on a sata hdd ..and it was non raid ..and after that you defaulted the BIOS settings ..you may need to check the sata bus and see how it is set .. and probably need to reinstall the operation system ..If you want to use it with raid ..set it before installing ..and make a large C drive for it to work cause windows alone will have almost 20 g after first update .. Also download and put the raid or ahci driver on a usb stick in case it will ask it (will not see the hard disk on raid without driver ..even if the windows 7 usually it works cause it has the driver on install..)
So ..check BIOS .. and see if it loads teh operation system when you put the hard disk sata on non raid or on compatible or on native .. it may be presented differently but the idea is teh same to disable ahci or raid for the hard disk ..and save changes and exit ..After that may work ..Also remove and reinsert ram memory and see if there is something wrong with it..and the last action reinstall cause a file from the boot sequence may be lost and this is the cause for not starting .. it happens when you do not format teh disk and it has an error on it .. For the other drives and partition ..it may be enough to make a defragmentation ..for now if you have files on them and you install only the C drive ..
Let me know if you still have problems with t ..
Jan 24, 2012 | HP TouchSmart Computers & Internet
Tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Let's get started!
When presented with the screen below. press the F8 key to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 | Computers & Internet
Hi - I have a Dell 8400, fails post. Diag indicators are A,B,C green and D amber. Sometimes the screen is black with a single blinking cursor and sometimes it shows the Dell splash screen. Cannot get to...
Unfortunately the dell website (not me) is not very helpful. Here's what is says about your diagnostic lights
Another failure has occurred.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
  • The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup (see "Boot Sequence") to make sure the boot sequence is correct for the devices installed on your computer.
  • If the problem persists, contact Dell.
Apr 20, 2010 | Dell Dimension 8400 PC Desktop
P5rd1-vm - will RAID setting delete my data
Suggest you enter the bios and make a setting change. Open the manual to page 2-24.
The M1573 RAID function set this to [Disabled].
(This will stop the bios from loading the RAID controller.)
See boot menu page 2-31 section 2.6
Set section 2.6.1 Boot device priority as shown.
(The drive with windows installation on it should be in the boot order).
You can also unplug either the data cable or power cable of the slave drive to assure it does not boot. If you still receive a blue screen with the primary drive suggest you re-install windows or boot to the windows CD and create a new partition within the free space of the primary drive. Install windows complete including updating. When finished you'll be able to copy you're data to the new windows. Use windows disk manger program (diskmgmt.msc) in the run window to delete the old windows partition.
Some programs will need to be reinstalled.
Link to Asus; http://www.asus.com/Search.aspx?SearchKey=P5RD1-VM
Cheers'
Mike
Mar 14, 2010 | ASUS P5RD1-VM Motherboard
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
Windows Server trying to boot from external hard drive
go into your 'update settings'. there is a section of where it asks you about how you want your settings set and where to send updates to. You may find the problem here. Check all the 'advanced' settings as well. If your Western digital is plugged in via USB and not requiring updates, unplug it while starting your system, after complete start up, reinsert the USB plug. It may show new devise found, then from here, you may be asked to reinstall it to stop the rebooting.
Aug 24, 2009 | Western Digital My Book Essential Edition...
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
My machine is Acer Aspire M7711 preinstalled with Genuine Windows Vista Home Premium.CPU Q8300, Geforce GTX 130, 600GB Default RAID Mode, 4GB Memory. My problem is Vista Home Premium Installation...
Im assuming its a new machine and when you first booted Vista failed. When you boot up, press the F10 key. This will take you to a menu to start your Acer machine from the begining. It takes a while for the first complete boot. I hope this answers your question. If not, post back and we'll diagnose your problem again. Best of luck!
Greg
May 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
How install new bios
After updated your bios, did you check the boot sequence?
it might have been changed. Go in to the bios again and check so the boot setting is pointed that your pc starts from your HDD.
If you trying to reinstall the OS you should change tye boot to start from you cd-drive.
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 12, 2008 | Intel Motherboard
Dell Dimension 8400 PC Desktop Logo
107 people viewed this question
Alun Cox
