Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Probe Alarm 'beeping' began without any operation of the stove. "Remove probe" message was displayed but the probr was not installed. "Cancel" would not stop the 'beeping', nor would setting of an oven function stop the beeping. Display continued to read "Remove Probe" and 'beeping' continued. I then found the probe in a kitchen drawer and plugged it in. Meassage changed to "check probe" (remember the probe had not been installed when the problem started). I then repeatedly inserted and removed the plug of the probe into the receptacle on the stove, but the problem persisted. As a last resort, I took the probe end (opposite the plug) and inserted into the oven-receptacle to 'short-out' the receptacle. That stopped the 'beeping' but a "check probe" measured is continually displayed (normal display for a shorted receptacle) Any ideas?
  • 1 more comment
  • Anonymous Feb 28, 2008
    same problem here - I'd rather not short it out. wtf is wrong with our jenn air?
  • sullibury Sep 30, 2008
    I am having the same problem except that mine is a JES9800aaw and I cannot find the probe (range was in when we bought the house) so we have had to just unplug it. I haven't been able to find anything on this error until I saw you post. Has anyone found a solution yet? I am assuming it will just be a matter of arranging a service call but what a pain since we never use that feature.
  • robert samples May 11, 2010
    how old is the range
5 Suggested Answers
SOURCE: probe light
I had the same problem today (my wife overflowed a pot of chicken stock last night, so there was liquid all over the cook-top, and some probably got down behind the control pannel). Based on the solution to a problem that seemed similar, though definitely not as exact as your description, I checked the probe connection (unscrewed the retaining nut, then unscrewed the two sheet metal screws holding the housing in place, then gave the probe connection a gentle tug to ensure that it was still properly connected). Finding nothing wrong, I replaced the housing and retaining nut, and the lights were no longer flashing.
Posted on Oct 22, 2007
  • 409 Answers
SOURCE: remove probe from oven
most electric ovens have a temperature sensing probe inside of them. this is to prevent the oven from overheating and causing a fire. the reason why it's asking you to do that is because it's either dislogged from its place or it need to be replaced.
Posted on Sep 13, 2008
milten1
  • 1304 Answers
SOURCE: Display says "remove probe" but no probe is installed
you can try to throw the breaker give it a few minutes and then reset the breaker
Posted on Oct 03, 2009
SOURCE: Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Posted on Dec 21, 2010
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Controls lost mind -- keeps asking for probe temp
Houston, we have a problem... Your electronic relay control, (ERC), is shot, kaput, no bueno and must be replaced in order to correct your situation. The ERC part number is 3191106, and retails for ~305.00 dollars! (I kid you not). I guess now is the time you might consider replacement over repair. That's a good question. If you choose to proceed with the repair, repost and I'll help with details on how to do it.
Aug 10, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kenmore KGSA906 display shows unplug meat probe when probe is not inplace and now we dont have any oven use
That's a communication error . U may need to replace the probe. If that doesn't solve the problem, you will need to replace the erc.
Nov 14, 2011 | Kitchen Ranges
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
My whirlpool gas stove displays a message F4-E1 and beeps. What is causing this?
F4-E1 is meat probe malfunction. Check the probe over and remove it see if that clears it.
Dec 18, 2010 | Whirlpool Ovens
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to cancel...how?
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Probe light
Jan 01, 2007 | GE Profile JGS968SHSS Gas Kitchen Range
Stove controls beeping and flashing "Probe"
Most likely oven sensor / probe is the problem. It can be tested with an ohm meter. Not sure about your model, but most should read around 1100 ohms at room temperature. If there's a tech sheet somewhere on your unit, it should tell you.
Sep 23, 2017 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
146 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
