Question about Canon MultiPASS MP700 All-In-One InkJet Printer
4x6 photos 1. What settings to I have to use to print successfully 2. Which way do I load the paper 3. How to I ensure that the colour I see on screen is what I get on the print Thank you for any assistance you might be able to provide
I fixed the problem quite easily, but had to go through a fairly lengthy process before finding out that you service was fee-paying. Sorry, but I charge also for supplying solutions...
Posted on Feb 16, 2008
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    How to load 4X6 photo paper Epson CX9400
    as i know there's no 4x6 photo paper, u just load original photo paper than print on your photo with the size that u already edit. may be you should try software that usualy use to printing postcard like this
    May 26, 2010 | Epson Stylus CX9400 Photo Printer
    My 4x6 prints are not centered on paper
    That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
    Nov 04, 2009 | HP DeskJet 940c InkJet Printer
    I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
    Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
    1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
    2. Click Start and then click Control Panel .
    3. Click Printers and Faxes .
    4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
    5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
    6. Make sure that the Source is box is set to Photo tray .
    7. Click the Borderless Printing box if borderless prints are desired.
    8. Click Apply and then click OK .
    9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
    Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
    Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
    At the printer:
    1. Remove any paper from the input tray
    2. Put a few sheets of 4x6 (10 or so) in the same tray
    3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
    On the computer:
    Open a picture
    Seect [File] [Print]
    Select the photo printer from the list
    Cick on [Preferences]
    See the paper type? select photo paper
    See the paper size? Select 4x6
    Quality (Best)
    [OK]
    [PRINT]
    Sep 28, 2009 | HP Office Equipment & Supplies
    Reprinting photos
    try using a ruler to check if you have the correct paper size.
    open up HP Solution Center verify the printer settings..
    use borderless printing, paper size 4 x 6.
    Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
    COLOR PRINTING FOR MY COMPUTER
    From the information you given it is very difficult to resolve your problem. Basically you have given no detail at all.
    Assuming You wish to print a colour document via the PC using a Windows based PC with the correct drivers installed and a full set of ink carts:
    1 Press [ON/OFF] to turn ON the machine.
    2 Load the paper in the Auto Sheet Feeder. (See page 23)
    3 Create a document or open a file to print.
    4 Open the printer properties dialog box.
       (1) Select [Print] from the application software's [File] menu.
       The [Print] dialog box opens.
       (2) Ensure that your machine is selected (1).
       (3) Click [Preferences] or [Properties] (2).
       The [Main] tab of the [Preferences] screen is displayed.
    5 Specify the required settings.
       (1) Click [Media Type] to select the type of media loaded in the machine
       (2) Specify the print quality and other settings in [Print Quality] or [Color/Intensity] AT THIS POINT, you need to ensure the box entitled GRAY SCALE PRINTING is NOT checked. Also ensure the Colour/Intensity option is set to AUTO
       (3) Click [OK]
    6 Print the document.
       (1) Click [Print] or [OK]
       The machine starts printing
    If any of the umpteen assumptions I have had to make are incorrect then post here what your exact configuration is and I will en devour to account for those particulars.
    Oct 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
    Canon MultiPASS MP700 All-In-One InkJet Printer Logo
    old marine
    old marine
