Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Belt I have a bissell pro heat model number7901-1 and i dont know how to put the belt back on. The old one broke and i cant find my book.
  • cookyvachon Feb 28, 2008
    What belt do I buy for the 7901-1 proheat
  • Anonymous Mar 13, 2014
    Don't know how to put belt back on pro heat steamer
    President:
  • 1,673 Answers
First take off the cover on the left side of the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Posted on Feb 14, 2008
Bissell quicksteamer 1950 motor
take bottom apart see if belt broke if bad check motor shaft see if it spins
Jul 31, 2017 | Bissell 1960-3 QuickSteamer Plus Upright...
I need to change the belt on my Bissell Pro heat. I dont know how to get to it!
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bncmdgh
May 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Moter belt
You can find the manual for your vacuum by clicking on this link: http://www.bissell.com/images/UserGuides/1697_207.pdf
May 05, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Replacing the little black rubber belt
bissell.com has videos on how to replace belts.
May 04, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Cant put belt on {goes to brushes}
bo to bissell.com and go to tech support maybe you can find it there,or just type the brand and model number followed by manual in your search browser and you will find all kins of places you can get it
Apr 13, 2009 | Vacuums
Belt broke
There should be an access panel on the top side of the cleaner. Pry this open with a screw driver and this should get you access to the area where the belt can be changed.
Apr 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Pump belt on bissell scrubber
If this is a Bissell Pro-Heat, then first take the belt cover off, it is on the left side on top of the noozle. Then turn it over, take out the one screw from the red lock, pull it off, then remove the cogged belt, take out the old pump belt if still on from underneath. Put a new one over the pump end, then feed it thru the opening and put it over the motor shaft. Put it all back together.
Feb 25, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
No spray
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Feb 23, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
73 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
