Need to replace dispenser unit in whirlpool awm 336
Hi, have a leak in my dispenser unit in whirpool awm 336 washing machine.
Have the new part but can't see how to remove the old one.
Need step by step instruction if possible.
Thanks
david
  • Muggle Feb 13, 2008
    Yes the soap - through trial and error I have managed it now, it was nessessary to remove the front plate and then undo three screws. So thanks sincerely for your help
    david
  • Gary Davd
    Gary Davd May 11, 2010
    Dispenser ?? for the soap??
OK, solved it now, you need to remove the front instrument panel first. This is held in place by four plastic lugs, two top and two bottom, which you can see when you remove the top of the machine. It's a bit fiddly since you don't want to break the lugs but a bit of patience gets it off clean. Next remove the two pipes that supply hot and cold water from the rear of the dispenser and also another pipe which fits onto the side. There are three small nuts to remove that secure the unit to the front of the machine and then by pushing it backwards and too the side it will slide out easily. Lastly there is a pipe to remove underneath the unit and then it is clear. Simply reverse the process to fit a new unit.
All the best
David
Posted on Feb 14, 2008
Manual for whirlpool AWG 336 -1000
hi everybody
i would need a manual of AWG 336 washing dryer
if somebody has it please send me a link or the manual to tundibundi64@gmail.com
thanks a lot!!
Dec 29, 2012 | Whirlpool Washing Machines
Hi i have whirpool awm 8900 and i have fault f11 what is this?
In your service manual it states for the f11 code
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
If you have any further questions message me back I await your reply Thanks again Rick
Jun 20, 2011 | Whirlpool AWM8000 Front Load Washer
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM 1203 Leaks water onto floor about 20 sec into wash cycle. Any solutions ?
It's either a perished door seal/bellow or perished pipe work most likey. Could even be a leak from the dispenser drawer
Mar 24, 2010 | Whirlpool AWM6100 Front Load Washer
Whirpoll AWM 6000 does not take water.
What to check next is the water inlet valve. To do it, turn on the machine and start the filling cycle. If you cannot hear a faint buzzing or humming noise from the water inlet valve, the solenoid coil is not getting any power. Check it's wiring. If you can hear some noise, you need to replace it. Make sure to unplug the unit before doing any service.
Oct 18, 2009 | Whirlpool Washing Machines
Hi i have whirpool washing machine whitemagic h65 stain wash. the tube which is connected to tap is leaking.
Replace gasket in connection to tap or other end.
Possible leak in tube if so replace tube.
Jun 10, 2009 | Whirlpool Washing Machines
F 19 error on Whirlpool AWM 8085
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Replace failed component.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 01, 2008 | Whirlpool AWM8163 Front Load Washer
Whirlpool washing machine Model AWM 5104/5
the despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Feb 25, 2008 | Whirlpool AWM5104/1 Front Load Washer
Awm 5145
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Jun 24, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
