Question about Samsung NV10 Digital Camera
Samsung NV10 lens won't retract/Autofocus doesn't work
My 1 year old Samsung NV-10 (just out of Warranty, of course) suddenly froze when powering off. The Lens only closes about 2/3 followed by 2 or 3 warning beeps. I gently tried to realign the lens tube by pushing on it with no result. I finally got frustrated and banged it against the desk so hard it move the lens out of alignment but that was easily restored by pushing it back into place. it seems firm and the lens revolve outward as they should when I power on but the autofocus does not work. When I power off the lens retracts 2/3rds of the way and gets stuck. I had a similar problem when I first bought the camera, got stuck open and would not open, close of take pictures. Got sent to Japan and repaired under warranty (cost me $25 for shipping for their defect!) it Took 6 or 8 weeks but it came back working fine...until now. I love the camera, the features the size, but am totally dis-satisfied with the quality and reliability. If anyone can suggest a way to fix this I would be greatful (the camera store told me it would be $250 to repair a $300 camera!) otherwise does anyone want to buy a $300 paperweight?
  • osalem Nov 17, 2008
    I have a samsung NV-10 digital camera. Recently the lens that pops out when you turn the camera on, is not stuck in the open, expanded position. Now when I turn the camera on, it beeps 4 times then turns off, with the lens expanded. Any idea how this can be fixed?
Please check your manufacture warranty as my samsung nv10 comes with a 2 year warranty
Posted on Oct 05, 2009
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
The lens piece that retracts when you turn off the camera and opens when your turn it on is not working. The Samsung NV10 will not open when turned on and makes a ding,ding sound and turns off. Any...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 22, 2010 | Samsung NV10 Digital Camera
Samsung TV turns itself off every 10/15 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
Hi! We have 10 year's old Canon PowerShotS50. Today I got E18, lens would not open or retract. I've tried all the methods on http://www.e18error.com/repair.html , no help. Than I followed one by one the...
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jan 08, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Ok my camera lens got stuck...so i fixed it...the fix didnt last long as after 10/15 mins it got stuck again...and keeps gettn stuck so now to take a picture i have 2 pull the lens out every time...what...
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 29, 2009 | Samsung NV10 Digital Camera
Autofocus function will not work on Canon 17 40mm 1.4 EF lens
Since the problem is limited to this lens, I highly doubt that you would have to replace the cameras AF sensors.
Since you only have the problem with this lens, I am afraid that you will have to get the lens repaired. Is the lens also 3 years old? Did you get it with MACK extended warranty?
Sometimes, Canon do these kinds of repairs for free, if they discover that there was some manufacturing error that caused it to fail. So be sure that you get it to a certified canon workshop.
I hope this helps,
/Chris
Nov 24, 2008 | Canon 35mm f/1.4L EF USM Autofocus Lens
Samsung NV10 - 4 bleeps on switching on then turns off
my camera started doing the same exact thing, did you ever get an answer?
Jan 20, 2008 | Samsung NV10 Digital Camera
I was able to contact the manufacturer who repaired my camera under warranty. They were wonderful to work with and my camera was only out of my hands for 10 days, out just before Thanksgiving and back just after! Amazing for a holiday time frame.
Sep 04, 2007 | Samsung Digimax 420 Digital Camera
Samsung NV10 Digital Camera Logo
175 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
