Question about Standard Horizon CP-1000C GPS Receiver
Orientation I can't get the unit to switch to heading up mode. It indicates heading up but stays in north up.
  • 113 Answers
It is not likely that there is a software error that could cause that problem so I'm going to cover some basic information first. Forgive me if I'm covering stuff you already know. There are 3 chart orientation modes, North Up, Heads Up, and Course Up. North Up you already know! In Heads Up mode, the chart will only orient heads up when the boat is moving. Unless you have an electronic compass interfaced to your GPS it has no way of knowing which way you are facing. Once you start to move, it compares your new position to the old position to determine which way is heads up. If you are not moving, the map defaults to North Up even if you are in heads up mode. Course Up mode is commonly mistaken for Heads Up. In Course Up mode, the GPS orients the top of the screen toward a waypoint that you have told the GPS to go to. If no waypoint is selected, the GPS will default to North Up orientation. So I guess what I'm saying is, make sure the boat is moving, and make sure you're not in course up mode (unless you want to be).
In the unlikely event that there is a software error causing this problem, it can easily be fixed by getting an update from Standard Horizon. You can either get them to send you an update chip, or download it online and copy it to a blank C Map card. When you turn the GPS there will be a message on the opening screen that identifies you software version. Get that information before you call Standard.
Posted on Feb 15, 2008
Have indicator lights on all round the car. hazards off and indicator switch in neutral and flasher unit pulled out and keys not in ignition
If you have an older car(early 90's) replace the head light switch. After that replace the turn signal switch.
Jun 28, 2015 | Cars & Trucks
Wiring Diagram Kawasaki GPZ 750
Kawasaki GPZ750 (ZX750) Turbo North American models.<br /><br /><img src="suzman_10.JPG" /><br /><br />1 - Right turn <br />2 - High beam<br />3 - Warning light<br />4 - Headlight fail<br />5 - Neutral<br />6 - Left turn<br />7 - Boost Guage <br />8 - Tach light<br />9 - Tach/volt switch<br />10 + 11 - Speedo lights<br />12 + 13 - Illum. lights<br />14 - Spare connectors<br />15 - LCD + warnig lights<br />15 + 16 - LCD illum<br />17 - RF indicator<br />18 - Horns<br />19 - Headlamp<br />21 - LF indicator<br />22 - Reserve lighting unit<br />23 - Hazard switch<br />24 - Indicator switch<br />25 - Horn switch<br />26 - Dimmer switch<br />27 - Starter lockout switch<br />28 - Neutral switch<br />29 - Side stand switch<br />31 - Oil pressure switch<br />32 - Alternator<br />33 - Regulator<br />34 - Solenoid<br />35 - Starter<br />36 - Battery<br />37 - Junction box<br />38 - LR Indicator<br />39 - Stop/tail lamps<br />40 - Stop/tail lamps<br />41 - RR Indicator<br />42 - Injectors<br />43 - Engine temp switch<br />44 - Boost sensor<br />45 - Fuel pump<br />46 - Air temp sensor<br />47 - Throttle sensor<br />48 - Main pump relay<br />49 - Fuel injection control unit<br />50 - Rear brake switch<br />51 - Pick-up coils<br />52 - Ignition control unit<br />53 - Coils<br />54 - Spark plugs<br />55 - Fuel level sensor<br />56 - Front brake switch<br />57 - Starter/engine stop<br />58 - Ignition<br />
on Nov 22, 2010 | Motorcycles
Iphone 4s user manual
In settings check if auto orientation is on. If you want the orientation stay fixed un check auto.
Aug 24, 2014 | Apple iPhone4 4G iPhone 4
Heat blows cold air
The LH models (LHS, Concorde, New Yorker, Intrepid, Vision) do have self-diagnostic capability with the standard type heater controls. I don't know about the Sebring heater controls (my '95 manual doesn't mention it) but if you have the various controlknobs/buttons that I will describe you could give it a try.
There is a rear window defogger that is initiated by a push button with an LED light. That light is the readout, by its blinking. To begin the diagnostic mode, run the vehicle at idle with the controls set as follows: the blower speed knob should be on any position other than OFF, the temperature knob should be set in full COOL, and the mode knob should be set on Defrost mode.
To enter the diagnostic mode, press the defogger switch in for five seconds, until it begins to blink, then release it. It will continue to blink for about 30 seconds while it calibrates. If it goes out, the calibration is OK and you can skip 3 paragraphs to "Position...mix mode" below.
If the light stayed on, switch the mode knob to the MIX (defroster-floor) position. If the light stays on there is a problem with the control head unit.
Switch the mode knob to the FLOOR position, if the light stays on, it indicates a problem in the blend door or the blend door actuator wiring.
Move the knob to the Bi-level (panel-floor) position where a continuous light indicates a problem with mode actuator or circuit.
Position the knob in the MIX mode. The LED light should now flash twice then pause, and continue a two-flash sequence, indicating that the MIX mode is OK.
In the FLOOR mode the light should flash three times, meaning that the FLOOR mode is OK.
In the Bi-Level Mode, a four-flash sequence indicates that mode is OK.
In the PANEL mode the light should flash 5 times to indicate no problems there, and in the recirc-panel mode 6 times and seven times in the recirc Bi-level mode.
The temperature control can be checked by switching the mode knob to Defrost and rotating the temperture knob. If the temperature contol is OK, the light will flash faster the more you turn the temperature knob up, until the light goes out at the hottest setting.
Switch the knob between Panel and Recirc-Panel and watch the recirc door (unit under the dash). Proper operation means that circuit and components are OK.
To get out of the self-diagnostic mode, turn off the blower or push the air conditioning button once.
If this doesn't seem to apply to your control head or you get no response from an LED light for the rear defroster, then the Sebring may not have this capability. Please let me know your results if any
Dec 02, 2010 | 2001 Chrysler Sebring
How do I use an orienteering compass to measure inclination?
Declanation (not inclanation) is different depending where you are located in the world. You can look up charts (magnetic lateral lines) on the net and they will tell you where your compass is pointing to, Magnetic north compared to TRUE north... Topographical maps will tell you how much to offset your compass to accomodate for declination...In degrees. I am no expert but I hope this steers you in the right direction. P.S. A compass always points to magnetic north not true north. Also I am not responsible for you getting lost ! lol
Oct 09, 2009 | Compass 337 "rothco" Orienteering
Change heading from north up to head up
In settings go to something like 'map feel'or 'orientation'. Depends a bit of the device.
Jul 03, 2009 | GPS
My humminbird 947c does not appear to be displying the correct heading while at the dock
Please go into the menu and select the 'Nav' tab then choose the 'Chart Orientation' setting and set to 'North - Up', also make sure 'North Reference' is set to 'True'.
If that doesn't work, reset the sounder back to factory defaults and try again.
Here's the manual to you sounder:
947C Manual
May 18, 2009 | Humminbird 947C GPS Receiver
Cannot find the indicator switch
Yes.. there is. It's called the 'FLASHER UNIT' Couldn't find any "Orientation Pics" (vehicle location), but it's usually been located under the driver's side dash:
May 04, 2009 | 1989 Hyundai Excel Hatchback
Furuno Radar Model 1833C
You have two things that orient the radar, on is called heading (or bearing) alignment. This is where you aim your radar so that a target comes up at 12 o'clock when dead ahead. Access this mode by pressing and holding menu duing power on, and go in to Installation Mode, radar setup, next page, align heading. I have posted a "tip" on this, search for VX2 radar alignment.
After this is done, North up is accomplished by having a magnetic input (fluxgate compass or autopilot). Calibration of this compass varies, but if it is accurate, then all should line up nicely.
Jul 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Standard Horizon CP-1000C GPS Receiver Logo
172 people viewed this question
Top Standard Horizon GPS Experts
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
