Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer from computer
Printer only prints out the left side when printing from E Mail or internet subject, Making a copy is fine, Also paper is pulled in very slowly.
Put in new cartridges, did alignment; printout is checked off and 2 birds are at bottom.
Bought all in one a year ago. HP says I need a new all in one
  • 1 more comment
  • villamom Feb 14, 2008
    what is page number D16. where do I find it. I do not have a manual
    Viilamom
    I checked rollers from front of printer.
    all clear, back has screws should this be opened Villamon
    I am looking thru the manual but so far doesn't seem to apply to my printer . I just printed out a letter I typed in Office 2007 and it printed out beautifully using printer 14 which is the one checked off in the control panel.
    Villamom
  • villamom Feb 15, 2008
    haven't heard from you, I seemed to have fixed the problem by changing the paper size in preference for e mail and options in internet web printing they were set on 4x6, I never changed them to that, it is suppose to change automatically.
    Do I get my money back since I solved the problem?
    Villamom
  • 983 Answers
If u are good at opening then just open it .... & clean the obstacles there may be obstacles...........
if not take it to technician......
please rate this solution........
Posted on Feb 13, 2008
  • 796 Answers
Hello sir
Hi Where do I load the paper in my Canon MX310?
The MX310 is a straight through printer. So you put the paper in the rear tray after opening it. Pull out the paper support and adjust the lever for the paper thickness to match your paper specifications. The lever goes to the left unless printing envelopes and T-shirt transfers. Also pull out the paper output tray and set the output tray extension.
Align the 4 corners of the paper stack (if loading more than one sheet) and bend to uncurl the paper (if needed) before inserting in the rear tray. For photo paper and other pages with a print side and a back, place the pages with the print side facing up. Align the paper against the right side of the rear tray and then pinch the paper guide and slide it to the left side of the paper stack. Make sure to adjust the paper size to match in the computer's printer properties (paper size) or in the copy settings on the all-in-one before either printing or copying.
Specific directions and pictures are in the Quick Start Guide that is available as a PDF here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals .
I hope this helps.
Dec 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Our Laser printer doesn't print on the left had side of the paper--well, very faint--the right side is just fine. I just replaced the cartridge. What is the problem?
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Jan 15, 2010 | Samsung CLP 300 Laser Printer
Printer prints fine on its own. Will not print
Try the following steps.
Press in the tab on the left side of the rear clean out door to release the door.
Remove the door from pulling it away from the printer.
Look for any paper bits /paper and removing a paper jam from the front may damage the printer.
Replace the rear door and press Cancel/ Resume to continue printing.
After this,
Uninstall and reinstall the software with the CD provided by the manufacturer. Turn off printer and system.
Remove the data cable and the power cable from the printer.
Press the power button for 20 seconds.
Aug 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
4 in 1 won't feed paper, makes a high pitched whine.
Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......Now try to Print it should work........
Thanku
Jan 06, 2009 | Lexmark X5495 Printer
Won't feed paper while printing
I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
