Question about Minolta Maxxum 7000 35mm SLR Camera
Shutter Blades out on Minolta Maxxum 7000 - Minolta Maxxum 7000 35mm SLR Camera
  • roysboy1957 Feb 13, 2008
    Hi, they are out of place...
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Meaning the blades don't open or they are out of place?
  • 667 Answers
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
Posted on Feb 13, 2008
Minolta maxxum 7000 flashing display
Shutter prob jammed and needs to be re-lubed, Common problem with this mode. Comes from lack of use.l
Apr 30, 2014 | Minolta Maxxum 7000 35mm SLR Camera
The camera will not take the picture
Need more info. What is the camera not doing? Does the auto focus work? Are the batteries good. Are the shutter blades in place? Sometimes when loading film a person will push down to smooth film and the force will go through the film and pop the shutter blades out of position. Remove the lens and gently lift the mirror with your finger nail. The blades should lie flat.
Jan 18, 2014 | Minolta Maxxum HTsi Plus 35mm SLR Camera
My Minolta Maxxum 400si film SLR seems to have a jammed shutter and the shutter curtains seem to be mis-aligned (this would be because of the previous owner, not me) but the bottom curtain actually seems...
With the shutter curtain out of place the camera will not function. If it is only out a little you may be able to persuade the shutter blades to fall back into position. If you bend them, or if they are out of the proper tracks then the camera will have to be sent to a repair service for repair.
Nov 23, 2009 | Minolta Maxxum 400si 35mm SLR Camera
I have a jammed shutter on my Minolta 400si SLR. It also has caught shutter curtains. I noticed this the moment I received it from an ebay seller. The shutter won't open beyond 1/4th of the way. No...
Can't fully see thru the lens
Look in the back where the film goes in. Are all the shutter blades flat and in place, or are they wrinkled or is one or two blades bent or out of place preventing the shutter from functioning fully? Put the camera in M focus and M exposure at about 15th, Fire the camera several times. If the shutter looks and works ok then take the lens off and look at the mirror. Fire the camera a few times. Doe the mirror go all the way up to the top and come back down, all the way? If so then the shutter would appear to work fine and the lens may e the problem. If the shutter or mirror box do not work correctly they will have to be repaired by a qualified technician.
Nov 19, 2009 | Minolta Maxxum 400si 35mm SLR Camera
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
lightspiritphotography.com
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Is the Minolta Maxxum 7000 capable of using infrared film?
goneoutthewi,
once the shutter is closed or the shutter open and the mirror is up no light strikes the film except the image. don't forget to use the red markings on the lens as infra-red focuses on a different plane than visible light.
Mar 27, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 troubleshoot camera wont take pictures
There are several possible reasons, it could be the body or the lens. Check the shutter blades without film. Are they smooth and in place, (flat)? It could also be related to the film, a mis-load of the roll. The lens could have some failure, possibly try another.
Jun 14, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
108 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
