Is it a new 4GB memory card? If so that might be your problem. The card would likely be an SDHC card, and your camera was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less).
But if the card is less than 2GB, it could have become corrupted. In this case you could try formatting the card in the camera to see if this would rejuvenate it. This will also erase the card. See this post if you wish to first recover those pictures.
Finally, if this is occurring with multiple cards, and is also saying "card locked" even though the tiny slide switch is in the unlocked position, then see this post for a possible remedy.
Reviewing old posts, and I just noticed this. I'm so sorry, but the second link was bad and in error. Please see this link instead if you're still encountering this problem.
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
