Question about Whirlpool RBS275PD Electric Single Oven
My oven will not preheat at all.Or basically get hot.
The top burners work,but the oven will not preheat or get hot.There are no error codes at all.What could be the problem?
  • 1 more comment
  • dee128 Feb 13, 2008
    Please
    Please help!I love to bake!
  • robert samples May 11, 2010
    when did this start after heavy baking or self clean
  • 4 Answers
HI THERE DEE WHEN U SWITCH ON YOUR OVEN DOES
1 THE FAN MOTOR IN THE OVEN ROTATE AND RUN
2 DOES THE OVEN HERMOSTAT TEMPERATURE LIGHT COME ON.
IF THE ANSWER TO THE 2 QUESTIONS IS YES THEN YOUR MAIN OVEN ELEMENT HAS BLOWN AND REQUIRES REPLACEMENT.
HOPE THIS HELPS
PERRY
Posted on Feb 14, 2008
  • 114 Answers
You most likely have a defective oven ignitor. Even if it IS glowing, (orange) it may not be creating the proper resistance to open the gas valve to the oven burner. Once the ignitor is replaced, your oven should come on within 30-45 seconds after you set temperature.
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Temperature light won't shut off after oven top cools down?
    the preheat light wont go off on my oven, and its not really hot. my oven light is on as well ,how do I turn off the preheat light
    Nov 30, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
    Oven takes long time to preheat
    if the oven has a glow bar it,s not staying hot enough to keep the main burner on change the glow bar
    Nov 23, 2013 | Whirlpool SB160PEE Gas Single Oven
    Oven appears to start, takes forever to preheat,
    This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Frigidaire FES367ASE Slide in range
    Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
    Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Kenmore oven - will not heat on bake / will heat on broil
    its your temp sensor. replace it and it should fix ur prob
    F2=overheat
    is your bottom element connected?
    Mar 23, 2009 | Kenmore Ovens
    Ge gas oven will not heat but burners work
    You will need to check the bake and broil igniters and/or the temperature sensor. A multi-meter should come in handy to verify if these components are good or bad.
    Sep 06, 2017 | Ovens
    Whirlpool RBS275PD Electric Single Oven Logo
    225 people viewed this question
    Top Whirlpool Ovens Experts
    Sal De
    Oloyede Monsuru
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
