Question about FrancisFrancis! X3 Espresso Machine
Francis!Francis!3X overheating I press middle button to draw a shot and steam sputters out instead of hot water
  • 1 more comment
  • Anonymous Nov 02, 2008
    I have the same problem
  • mcbeth1234 Jan 25, 2009
    my Francis Francis X5 is blowing a fuse
  • pabzilla Feb 26, 2009
    Same problem. Seems that the temperature sensor is in bad shape or something.
  • 3 Answers
Your thermostat has failed. The middle button is the pump. The bottom button is for the steam mode. If you are getting steam instead of hot water when using the pump, then the boiler is way too hot. Either adjust the thermostat or try descaling the boiler.
Posted on May 09, 2009
The two solutions above really miss the point. The first identifies the 3-way valve as the problem, and suggest a back flush. The FF X3 does not have a 3-way valve, and can't be back flushed. The second is basically giving instructions on how to use a machine with three buttons: on-off, espresso, steam. No offense, but don't you think that's a bit patronizing?
Posted on Feb 26, 2009
I think you are pressing the wrong button to draw a shot...
Top button is power on/off.
Middle button is for steam (high temp) when pressed in.
Bottom button is to activate pump.
If not used for a while, or just becuase it can't hurt, you can prime the machine by first turning the power on, place something under the steam wand, open the steam wheel, and press both the steam (middle) button and the pump (bottom) button. Allow about a cup of water to pump out the steam wand and then you know the machien is fully primed. Good luck.
Posted on May 14, 2008
Sounds like a clogged three-way valve - you should try and backflush the machine
Posted on Mar 05, 2008
I have a Francis Francis x1 machine, but when i want to make an espresso shot, and turns on the espresso button, the steamer spour out boiling water (not steam, and not while turned on). Does anyone k
Don't know how your controls are set, but you have two switches on the front and a knob on the right. The switch for the steamer (the right hand switch) should be off. The knob on the right should be turned clockwise to turn in off. Then no water or steam should come out of the steamer wand. If it does, the seal on the knob inside the machine is broken. It can be repaired but only if you're handy with a screwdriver (make sure if you take it apart you disconnect it from the mains).
Jun 24, 2014 | FrancisFrancis! Coffee Makers & Espresso...
Francis francis milk steamer not operating
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
May 19, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Water through frothing wand
It might sound silly but you haven't got the steam valve on the right hand side open have you?
Nov 27, 2008 | Gaggia Evolution Espresso Machine
Francis Francis X 4, milk steam not working !
Is it coming out something at all though the steam nossle? if tis not its probably blockage in the steam pipe, trie and clean it.
if its dripping och just coming out alitle water from the steam nossle i would trie and descale the machine.
Jul 15, 2008 | FrancisFrancis! X4 Espresso Machine
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
FrancisFrancis! X3 Espresso Machine Logo
888 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
