Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
External Hard drive
By Azzoosmit79 on Feb 13, 2008
Need drivers for Windows XP Pro sp2
Same Problem
Apr 11, 2009
-   Same problem my computer detects drive not showing contents, can't find drivers . Who we be the first to find it ? Let the race begin, hope to here from somebody.
Cln246
-   cln246
Mar 28, 2009
-   I had the same problem and it turned out I was using the wrong power adapter. The size of the insertion plug is very common. Be sure it the one seen here: power supply
Once I corrected this, all was well!
-   orko1978
Mar 17, 2009
-   In windows Xp 1 TB external hard disk detected but not showing content -   Guest
Mar 12, 2009
-   I have exactly the same problem as the user above.
Is there a drive?
I wonder if it is something to do with the fact that I have only ever used this 160gb Ext HD on a MAC.
Could that have something to do with?
-   Guest
Mar 11, 2009
-   I have the same problem with the Seagate FreeAgent Go 500 GB USB 2.0 Hard Drive. and I cant find a driver to download to fix the problem. Where can I get the driver for this hard drive?-   christoph609
Best Solution
posted on Aug 15, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i had the same problem, but once i plugged it straight into the wall socket it seemed to work fine. just make sure that the end of the UBS cable that plugs into the my book has not come loose as this may also cause a disconnection.
Solution #2
posted on May 25, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I too was having trouble with my WD external drive. One day it was working fine - the next it was not recognized on any ports. Listed as an Unknown device and no drivers installed.
I tried the solution listed above - unpluged it from the power strip, pluged it into a wall socket and ALL WORKS! Darnedest thing I ever seen.
Solution #3
posted on May 24, 2008
Very Helpful)
moshkinstein
Rank: Apprentice
Rating: 98%, 3 votes
When I switched on my computer one day, Western Digital drivers were not found.
This works:
I have changed plug sockets, power strip to wall socket and now Western Digitals are now being detected.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on May 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I did a Google search and found another user having the same problem! Apparently the problem goes away if you plug the drive directly into a wall outlet, and not to a power strip.
I did the same thing and it works! Weird, but at least it works for me... No need for any downloading drivers or whatever,.
Solution #5
posted on Dec 28, 2008
Somewhat Helpful)
lizard69
Rank: Apprentice
Rating: 75%, 2 votes
I need drivers for my simpletech external hard drive model number 96300-40001-001
Was this helpful?
Yes
No
Solution #6
posted on Dec 26, 2008
Not Rated)
wchaz1
Rank: Apprentice
Rating: 0%, 0 votes
I switched the USB cable to my camera's (Canon) USB cable and it worked. The WD drive is plugged in a powerstrip.
Was this helpful?
Yes
No
Solution #7
posted on Nov 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
does anyone understand why this solution works?  it makes no sense.  the drive mounted find and worked for months on the same power strip, now, suddenly, it needs to go directly from a wall outlet?
Solution #8
posted on Oct 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Well just look at ur mom or u could try fuckin' yourself one or two time kk plz tnx lol
Solution #9
posted on Aug 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
dumbest problem reason ever. but the solution does work.
Solution #10
posted on Jun 07, 2008
Not Rated)
dawn8459
Rank: Guide
Rating: 86%, 7 votes
have a MicroNet 80GB hard drive PHD8072U2F my son gave me and on another older computer had saved some of my files from....anyway cannot get to other computer and the one I am using is another sons and I need some of my documents on this external drive and cannot find a driver for it to download and be able to even use it. Please help, I am fighting to keep my home and the documentation is on this drive and only on it..... One thing I learned is I will do what I wanted to do in the first place and have at least a double back up plan.....sons thought I was over concerned...I know if it can happen it will to me and should have done it but was a financial burden and listened to them. Thanks and God Bless email dawn8459@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
my playstation 3 wont read my iomega external hard drive, its 1TB. how can i make it so that it... (More)
Answer
My computer does't recognize CADB001U32 1TB HD after install/uninstall utility program? It says that... (More)
Answer
I'm having trouble connecting my Belkin wireless N+ router to a Western Digital Passport 500gb... (More)
Answer
I have an external drive that has both USB and eSATA. The USB connection would work perfectly but... (More)
Answer
my computer stopped recognizing the drive after i installed a utility program. I uninstalled the... (More)
21 Other Users Have The Same Problem - Continued
Comment by viking006, posted on Jan 24, 2009
I have a LaCie 160Gb external HD that does not install on PC with XP Home Ed.
PC detects HD and when asking for automatic or manual installation, neither works. Messages reads: An error occured and your hard ware may not be installed correctly. Invalid data.
The HD does not appear on desktop and on the hardware manaegment application it signals with a small exclamation mark that there is indeed a problem with the external HD related to drivers...
Comment by taniapaoli, posted on Jan 21, 2009
i have the same problem and it asks me to insert the software
Comment by izokay, posted on Jan 15, 2009
i deff could use a driver
Comment by dbmcgirt, posted on Jan 08, 2009
when i plug in wd my book to my dell xps it tells me that the usb device is not recognized
Comment by pumken, posted on Dec 23, 2008
I have a simpledrive product number starting 90300. It works fine on two computers but not on the dell which we use most. I have XP and it should plug and play?
Comment by Guest, posted on Nov 16, 2008
has any found the drivers for this device
Comment by Guest, posted on Nov 14, 2008
tak
Comment by makhtar, posted on Nov 13, 2008
Same driver problem
I came home after work and found that my XPSP3 saying that Peninfarina 320 is unknown USB device.
Comment by Guest, posted on Oct 31, 2008
i looked on simpletech's website and found nothing as far as drivers for my 320 gb external hard drive so my computer wont recognize it
Comment by Guest, posted on Oct 26, 2008
I would like to download some drivers for this product where can i get the drivers from
Comment by dwwittenberg, posted on Oct 12, 2008
My hard drive is no longer recognized by my computer
Comment by SgtP, posted on Aug 12, 2008
I have a 1TB SimpleTech Pininfarina that was working properly and now it is saying that it cannot find the drivers.
Comment by paul l34, posted on Jul 12, 2008
I am having the same issue. My WD book connects just fine to my laptop, using the same outlet and the same USB cable. Whenever I have the WD device connected, it locks everything up. As soon as I unplug the USB cable, everything else on the pc works again. Many of the solutions I've seen online for this issue are Vista specific. There must be something else here. Please help!
Paul
Comment by prafulpai, posted on Jul 07, 2008
I am facing a similar problem with my Seagate 160GB drive, my OS is Vista basic with all updates but still unable to use the external drive. It keeps on telling me driver cannot be installed.
I checked the same drive on a friend's Desktop which is XP, its working fine there...................plz help
Comment by Guest, posted on Apr 06, 2008
Please describe the specifics of your problem below. We'll add
your post as a comment to Azzoosmit79's External Hard drive problem, and notify you when a new solution is offered.
Comment by d00d23, posted on Feb 16, 2008
i am having the same problem with my 500GB WD external drive. xp keeps prompting me for drivers every time i plug it in to my pc. my install of xp is up to date with windows updates. i even let the found new hardware wizard search the internet for the drivers and it came up with nothing. anyone have a link to the drivers or an article?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hard Drives:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
