SOURCE: bad earth connection on a 2001 renault master van
its definatly in the back lights. i have seen this problem before. the earth at the rear of the car on the left side beside where the loom plugs into the bulbs holder. 10 mm bolt bolted to the body. loosen it and say it with electrical cleaner and do the same on the opposite side. shoul do he job
SOURCE: Renault laguna 1.9 dti, 2000 'v' reg, old shape
Your problem is you have a bad connection somewhere like at parking lights/stoplights/rear lights/so what you do is remove all parking and rear lights then turn on indecators and check the lightsyou will find that one of them has a bad earth and when you put them back in the lights flash dimmly and thats the one with a bad connection or a bad earth going to that light.
Let me know if you still have a problem Ron
SOURCE: my renault clio has an issue with the rear lights
yes somewhere is a dodgy earth on the back light cluster ,either one side or both ,renew the earth and oil the bulbs with engine oil to prevent corrosion ,also make sure the correct bulbs are in the holders look on bottom of bulb and inside the holder ,be surprised how many bar room mecahnics their are and the more they drink the more they know ---
